[mapserver-users] I: Apache crash using Mapserver with big
mapfile(about 2500 lines)
ritesh ambastha
ritesh.linux at gmail.com
Fri May 15 13:17:44 EDT 2009
Hey,
Larger size of mapfile is not the culprit over here. I have used mapfile of
more than 20K lines. Issue is something else. I don't know much about it but
it seems like you have a glibc version conflict on your box. But, I am sure
and 100% confident that mapfile size is not an issue.
When you get warnings like "glibc detected malloc()/free()/double", they
indicate that the heap has been corrupted. One work around is to use
DieHard, which replaces your memory allocator with one that is unaffected by
most of these errors (www.diehard-software.org).
Note: "I dont work for DieHard. I just got some reference of it on web"
Regards,
Ritesh Ambastha
Edgardo Ghibaudo wrote:
> Steve,
> I compiled mapserver with -enable-debug option.
> Then I launched shp2img in the following way:
> ./shp2img -all_debug 5 -m /opt/fgs/apps/mapservergeo/map/at7_2_3.map
> [Fri May 8 10:45:49 2009].96896 msDrawRasterLayerLow(Sfumo): entering.
> [Fri May 8 10:45:49 2009].105123 msDrawGDAL(): src=704,474,913,1009,
> dst=0,0,470,520
> [Fri May 8 10:45:49 2009].105479 msDrawGDAL(): red,green,blue,alpha bands
> = 1,2,3,0
> [Fri May 8 10:45:49 2009].277761 msDrawMap(): Layer 0 (Sfumo), 0.181s
> [Fri May 8 10:45:49 2009].288732 msDrawMap(): Layer 7 (Edificato), 0.011s
> *** glibc detected *** free(): invalid next size (fast): 0x0846d138 ***
> Aborted
> Edgardo
> -----Messaggio originale-----
> Da: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Inviato: giovedì 7 maggio 2009 19.29
> A: 'mapserver-users at lists.osgeo.org'; Edgardo Ghibaudo
> Oggetto: Re: [mapserver-users] Apache crash using Mapserver with big
> Have you tried running through shp2img independently of MapLab to see if
> it's a problem with MapServer or
> MapLab specifically?
> Steve
> --http://www.provincia.biella.it------------------------------------------------------
> Vuoi rimanere sempre aggiornato sulle nostre attivita'?
> Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione
> di interesse.
> --Avviso------------------------------------------------------------------------------
> Questo messaggio e i suoi allegati sono riservati esclusivamente alle
> persone in
> indirizzo e possono contenere informazioni confidenziali. Se questo
> messaggio vi e'
> pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
> In questo caso rispedite immediatamente il messaggio al mittente e
> cancellatelo.
> Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it.
> Grazie -Il Webmaster.
> --Warning-----------------------------------------------------------------------------
> This message and its attachments are addressed solely to the persons
> above and may
> contain confidential information. If you have received the message in
> error, be
> informed that any use of the content hereof is prohibited.
> Please return it immediately to the sender and delete the message.
> Should you have
> any questions, please contact us by replying to ced at provincia.biella.it.
> The Webmaster.
View this message in context: http://n2.nabble.com/I%3A-Apache-crash-using-Mapserver-with-big-mapfile%28about-2500-lines%29-tp2844265p2908941.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
