[mapserver-users] select one column values from a table
meenu
meenu.monu at gmail.com
Tue May 19 07:25:58 EDT 2009
hi friend...i am not using postrgis method for this...so am prefering the
first option...
in a while loop how can i check till the end of records( not fields)...
ur mentioned code is taking layer.numitems - 1 ...it is checking all the
field count...instead of that how i cancheck record nos??
Meenu
View this message in context: http://n2.nabble.com/select-one-column-values-from-a-table-tp2931342p2938939.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
