[mapserver-users] select one column values from a table
Paolo Corti
pcorti at gmail.com
Tue May 19 09:49:25 EDT 2009
meenu wrote:
> hi friend...i am not using postrgis method for this...so am prefering the
> first option...
> in a while loop how can i check till the end of records( not fields)...
> ur mentioned code is taking layer.numitems - 1 ...it is checking all the
> field count...instead of that how i cancheck record nos??
this should make the trick (couldn't test now):
for(int i=0; i<layer.getNumFeatures; i++)
shapeObj shape = layer.getFeature(i, -1);
for (int i = 0; j < layer.numitems; i++)
Console.WriteLine("Field " + layer.getItem(j) + ", Value=" +
shape.getValue(i));
View this message in context: http://n2.nabble.com/select-one-column-values-from-a-table-tp2931342p2939629.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
