[mapserver-users] Problems getting a JP2 or TIFF raster layer
drawen
Michael Da Silva Pereira
michael.dasilvapereira at iburstafrica.com
Wed May 27 12:06:15 EDT 2009
It displays everything normally, except the raster, which is just not drawn
GDAL: Auto register /usr/lib/gdal15plugins/gdal_GRASS.so using
GDALRegister_GRASS.
[Wed May 27 18:04:41 2009].197691 msLoadMap(): 0.570s
[Wed May 27 18:04:41 2009].414187 msDrawMap(): Layer 0 (vereenigingroads),
0.194s
[Wed May 27 18:04:41 2009].414307 msDrawRasterLayerLow(2627D): entering.
JPEG2000: IHDR box found. Dump: width=20018, height=22269, numcmpts=3, bpp=8
JPEG2000: Component 0: bpp=8, signedness=0
JPEG2000: Component 1: bpp=8, signedness=0
JPEG2000: Component 2: bpp=8, signedness=0
GDALJP2Metadata: Got projection from GeoJP2 (geotiff) box: PROJCS["WGS 84 /
UTM zone 35S",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.2572235629972,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32735"]]
GDAL: GDALOpen(/var/www/ms-tmp/./2627D.JP2) succeeds as JPEG2000.
GDAL: GDALClose(/var/www/ms-tmp/./2627D.JP2)
[Wed May 27 18:04:46 2009].785278 msDrawMap(): Layer 1 (2627D), 5.371s
[Wed May 27 18:04:46 2009].786307 msDrawMap(): Drawing Label Cache, 0.000s
[Wed May 27 18:04:46 2009].786388 msDrawMap() total time: 5.588s
[Wed May 27 18:04:46 2009].829842 msSaveImage() total time: 0.043s
[Wed May 27 18:04:46 2009].830048 msFreeMap(): freeing map at 0x9732ac8.
[Wed May 27 18:04:46 2009].830136 freeLayer(): freeing layer at 0x9739718.
[Wed May 27 18:04:46 2009].830201 freeLayer(): freeing layer at 0x9862a68.
[Wed May 27 18:04:46 2009].830240 freeLayer(): freeing layer at 0x991bb38.
[Wed May 27 18:04:46 2009].830289 shp2img total time: 6.202s
GDAL: GDALDeregister_GTiff() called.
2009/5/27 Frank Warmerdam <warmerdam at pobox.com>
> Michael Da Silva Pereira wrote:
>> I am trying to display from browser using browse mode,
>> /home/michael/mapserver-5.4.0/shp2img -m global.map -o test.png -all_debug
>> 1000
> Michael,
> And what output do you see? You might also try setting the CPL_DEBUG
> environment variable to ON.
> eg.
> export CPL_DEBUG=ON
> 1000
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
Regards,
Michael da Silva Pereira
Mobile: +27 84 245 2376
Office: +27 11 251 2036
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090527/cf801651/attachment.html
