[mapserver-users] Mapserver/PostGIS map file problem (double
quotes in layer 'DATA' element)
Simon Haddon
simon at sibern.com.au
Wed May 27 20:27:14 EDT 2009
Thanks, Now I just need that chest. lol
On Wed, 27 May 2009 16:29:54 -0700, Peter Willis <peterw at borstad.com>
wrote:
> Hello,
> Darn!, I just sent a [RESOLVED] with the same solution.
> (just as I was receiving your email...)
> Yes, this is how I managed to to make it work.
> Everything works now.
> I guess you get the badge for that one.
> Thanks for your help.
> Peter
> Simon Haddon wrote:
>> Have you tried
>> DATA 'the_geom from (select oid,gid, the_geom,
>> "Area","Perimeter","PixelValue" FROM "global_Land_poly" WHERE
>> "PixelValue"=1 )
>> AS FOO using SRID=4326'
>> The other options is to change the table name and column names to be
>> lower
>> case or case insensitive. Mixed case table and column names are always a
>> pain in any database system.
>> If you can't modify the table then try creating a view and using the
view
>> in your query instead. Make sure your view is created all lower case
>> without quotes. This will probably mean you will need to alias your
>> select
>> to lower case the column names and you will probably have to add it to
>> the
>> postgis geometry tables manually but other than that it will work.
>> Cheers,
>> Simon
Cheers,
SIMON
