[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Paul james
pauljame at gmail.com
Fri May 29 13:59:08 EDT 2009
1 - I tried with 1500,1400,1310,development version(1500) and ms4w beta...
2 - I´m using normal CGI
3 - My tests are only with Postgis... I´ll generate a shapefile to test
later ...
Paul
On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi Paul,
> Did you experience the same with the release-1310 and release-1400
> versions? Did you experience the same with the development version?
> Are you using fastCGI or normal cgi?
> Is this just a PostGIS related problem or you get the same with a simple
> shapefile?
> Sorry for the bunch of the questions...
> Best regards,
> Tamas
> 2009/5/29 Paul james <pauljame at gmail.com>
>> Yes Daniel... I deleted all previous files and put only 5.4 files... My
>> mapscript application is working fine on 5.4...
>> But the CGI dont...
>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>> Paul
>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>> dmorissette at mapgears.com> wrote:
>>> Paul james wrote:
>>>> Hi Daniel...
>>>> I got the binaries from Tamas build :
>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>> And from MS4W 3.0 beta2...
>>>> Same result with both...
>>>> That error you got is my fault... I took off the :
>>>> IMAGE "..\Map.png"
>>>> from REFERENCE definition when copy the code to email...
>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>>> Just replacing with 5.4 binary I got that 502 error...
>>> Hopefully you always make sure you update all DLLs as well when you
>>> "replace with 5.4 binary"? Even if the DLLs have the same names, if they
>>> come from different build environments or versions they may not be
>>> compatible and could cause the kind of crashes that you are experiencing.
>>> Daniel
>>> Daniel Morissette
>>> http://www.mapgears.com/
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090529/306158ec/attachment-0001.html
