[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI
error on IIS(5.1 and 6.0) ... Possible BUG?
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri May 29 14:01:32 EDT 2009
What's the full URL submitted against the CGI?
>>> On 5/29/2009 at 12:59 PM, in message
<33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>, Paul
james
<pauljame at gmail.com> wrote:
> 1 - I tried with 1500,1400,1310,development version(1500) and ms4w
beta...
> 2 - Ím using normal CGI
> 3 - My tests are only with Postgis... Íll generate a shapefile to
test
> later ...
> Paul
> On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com>
wrote:
>> Hi Paul,
>> Did you experience the same with the release-1310 and release-1400
>> versions? Did you experience the same with the development version?
>> Are you using fastCGI or normal cgi?
>> Is this just a PostGIS related problem or you get the same with a
simple
>> shapefile?
>> Sorry for the bunch of the questions...
>> Best regards,
>> Tamas
>> 2009/5/29 Paul james <pauljame at gmail.com>
>>> Yes Daniel... I deleted all previous files and put only 5.4
files... My
>>> mapscript application is working fine on 5.4...
>>> But the CGI dont...
>>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>>> Paul
>>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>>> dmorissette at mapgears.com> wrote:
>>>> Paul james wrote:
>>>>> Hi Daniel...
>>>>> I got the binaries from Tamas build :
>>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>>> And from MS4W 3.0 beta2...
>>>>> Same result with both...
>>>>> That error you got is my fault... I took off the :
>>>>> IMAGE "..\Map.png"
>>>>> from REFERENCE definition when copy the code to email...
>>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>>>>> Just replacing with 5.4 binary I got that 502 error...
>>>> Hopefully you always make sure you update all DLLs as well when
you
>>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
if they
>>>> come from different build environments or versions they may not
be
>>>> compatible and could cause the kind of crashes that you are
experiencing.
>>>> Daniel
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
