[mapserver-users] MapServer + Tilecache
Roger André
randre at gmail.com
Thu Nov 5 13:22:47 EST 2009
Hi Tyler,
I wonder if the "projection" line in your tilecache.cfg might be causing
problems? From what you show below, it looks like your "vias" data is in
EPSG:4326 natively, and that you then force MapServer to reproject it to a
custom mercator - which you say works fine.
I think the "projection" and "srs" lines are conflicting with each other in
your tilecache.cfg.
In my setup, I have my data's native projection defined in the mapfile like
you do, as 'PROJECTION "init=epsg:4326" END'. But in my tilecache.cfg, I
only specify what output projection I want, in this case EPSG:900913.
[v2_20m_global]
type=MapServerLayer
mapfile=/var/www/mapfiles/v2_20m_global/v2_20m_global.map
metaTile=true
metaSize=2,2
metaBuffer=0,500
layers=imagery
spherical_mercator=true
srs=EPSG:900913
My suggestion would be to remove the "projection line entirely and see if
you get tiles generated in EPSG:4326 correctly. If that works, try
specifying a different EPSG code. If you get reprojected tiles that way,
you can try fiddling with the "projection" parameter in the tilecache.cfg,
or add a new projection line to your /share/proj/epsg file with your custom
parameters and point to its code in the tilecache.cfg "srs" line.
Best of luck,
Roger
On Wed, Nov 4, 2009 at 10:52 AM, Tyler Durden <tylersticky at gmail.com> wrote:
> Hi all,
> I'm new to MapServer, until now I've used Mapnik to generate my tiles.
> But I want to try MapServer and I can't figure out what I'm doing
> wrong.
> If I run via WEB interface it renders fine, but with Tilecache the
> tiles appears blank.
> Any idea what I'm doing wrong?
> Thanks in advance.
> MAP
> NAME "test"
> EXTENT -961006 5034756 -955378 5036634
> IMAGECOLOR 255 255 0
> IMAGETYPE JPEG
> SIZE 256 256
> STATUS ON
> UNITS METERS
> MAXSIZE 5000
> SHAPEPATH "/home/tyler/Projects/Python/mapserver/tilecache/vias/"
> PROJECTION
> "proj=merc"
> "a=6378137"
> "b=6378137"
> "lat_ts=0.0"
> "lon_0=0.0"
> "x_0=0.0"
> "y_0=0"
> "k=1.0"
> "units=m"
> "nadgrids=@null"
> "wktext"
> "no_defs"
> END
> LAYER
> NAME vias
> TYPE LINE
> DATA vias
> STATUS default
> OFFSITE 0 0 0
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> NAME "Countries"
> OUTLINECOLOR 0 0 0
> END
> TRANSFORM true
> END
> tilecache.cfg:
> [cache]
> type=Disk
> base=/home/tyler/Projects/Python/mapserver/tilecache/cache
> [base]
> type=MapServerLayer
> layers=vias
> mapfile=/home/tyelr/Projects/Python/mapserver/tilecache/vias.map
> projection=+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
> +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs +over
> bbox=-20037508,-20037508,20037508,20037508
> maxResolution=2000
> srs=EPSG:4326
> levels=12
> extension=jpeg
> size=256,256
> metaTile=yes
> metaBuffer=512
> metaSize=5,5
> debug=on
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091105/9b719c40/attachment-0001.html
