[mapserver-users] MapServer, WFS and Oracle
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Nov 18 05:51:29 EST 2009
You seem not to get even a single feature back, all you get is an empty bounding box. How does you GetFeature request look like?
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Jelmer Baas
> Lähetetty: 18. marraskuuta 2009 12:11
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] MapServer, WFS and Oracle
> Hello list,
> I'm trying to get MapServer running as a WFS server with an
> Oracle data source. When using TAB files I have no problem,
> also using the Oracle datasource and letting MapServer draw
> it (WMS) works properly.
> However, the WFS request only returns one result (a correct
> one). My total resulting XML is:
> <wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://mapserver.gis.umn.edu/mapserver
> http://x.x.x/scripts/mapserv.exe?map=address.map&SERVICE=WFS&V
> ERSION=1.0
> .0&REQUEST=DescribeFeatureType&TYPENAME=address&OUTPUTFORMAT=X
> MLSCHEMA">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:4326">
> <gml:coordinates>5.172200,52.038485
> 5.173701,52.038853</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> There should be more results (confirmed by the WMS image and
> by monitoring the query in Oracle). I also set DUMP to true
> and "gml_include_items" "all" in my layer METADATA, so I also
> expected more fields. My layer definition is as follows:
> LAYER
> NAME address
> TYPE point
> CONNECTIONTYPE oraclespatial
> DATA "GEOLOC FROM ADDRESS USING SRID 90112 VERSION 10g"
> CONNECTION "x/y at z"
> DUMP TRUE
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CLASS
> SYMBOL "circle"
> OUTLINECOLOR 255 0 0
> SIZE 6
> NAME "address"
> END
> PROJECTION
> "init=epsg:28992"
> END
> METADATA
> "wfs_title" "address"
> "wfs_srs" "EPSG:28992 EPSG:900913"
> "wms_title" "address"
> "wms_srs" "EPSG:28992 EPSG:900913"
> "gml_featureid" "ID"
> END
> END
> Any idea what I'm doing wrong? I'm using MapServer 5.4.2 with
> Oracle 10g.
> Regards,
> Jelmer Baas
