[mapserver-users] MapServer, WFS and Oracle
Jelmer Baas
Baas at speerit.nl
Wed Nov 18 06:05:41 EST 2009
Jukka,
Thanks for the quick reply. The request is:
mapserv.exe?map=address.map&typename=address&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=1.171946062917749,52.038473357169345,5.173921509856943,52.03887593415947
(Very zoomed out)
If this is another projection issue, I'm going to eat my shoe. ;)
Regards,
Jelmer
> -----Original Message-----
> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> Sent: woensdag 18 november 2009 11:51
> To: Jelmer Baas; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] MapServer, WFS and Oracle
> Hi,
> You seem not to get even a single feature back, all you get
> is an empty bounding box. How does you GetFeature request look like?
> -Jukka Rahkonen-
> > -----Alkuperäinen viesti-----
> > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Jelmer Baas
> > Lähetetty: 18. marraskuuta 2009 12:11
> > Vastaanottaja: mapserver-users at lists.osgeo.org
> > Aihe: [mapserver-users] MapServer, WFS and Oracle
> > Hello list,
> > I'm trying to get MapServer running as a WFS server with an
> > Oracle data source. When using TAB files I have no problem,
> > also using the Oracle datasource and letting MapServer draw
> > it (WMS) works properly.
> > However, the WFS request only returns one result (a correct
> > one). My total resulting XML is:
> > <wfs:FeatureCollection
> xsi:schemaLocation="http://www.opengis.net/wfs
> > http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> > http://mapserver.gis.umn.edu/mapserver
> > http://x.x.x/scripts/mapserv.exe?map=address.map&SERVICE=WFS&V
> > ERSION=1.0
> > .0&REQUEST=DescribeFeatureType&TYPENAME=address&OUTPUTFORMAT=X
> > MLSCHEMA">
> > <gml:boundedBy>
> > <gml:Box srsName="EPSG:4326">
> > <gml:coordinates>5.172200,52.038485
> > 5.173701,52.038853</gml:coordinates>
> > </gml:Box>
> > </gml:boundedBy>
> > </wfs:FeatureCollection>
> > There should be more results (confirmed by the WMS image and
> > by monitoring the query in Oracle). I also set DUMP to true
> > and "gml_include_items" "all" in my layer METADATA, so I also
> > expected more fields. My layer definition is as follows:
> > LAYER
> > NAME address
> > TYPE point
> > CONNECTIONTYPE oraclespatial
> > DATA "GEOLOC FROM ADDRESS USING SRID 90112 VERSION 10g"
> > CONNECTION "x/y at z"
> > DUMP TRUE
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > CLASS
> > SYMBOL "circle"
> > OUTLINECOLOR 255 0 0
> > SIZE 6
> > NAME "address"
> > END
> > PROJECTION
> > "init=epsg:28992"
> > END
> > METADATA
> > "wfs_title" "address"
> > "wfs_srs" "EPSG:28992 EPSG:900913"
> > "wms_title" "address"
> > "wms_srs" "EPSG:28992 EPSG:900913"
> > "gml_featureid" "ID"
> > END
> > END
> > Any idea what I'm doing wrong? I'm using MapServer 5.4.2 with
> > Oracle 10g.
> > Regards,
> > Jelmer Baas
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
