[mapserver-users] MapServer, WFS and Oracle
    Bart van den Eijnden
    bartvde at osgis.nl
    Wed Nov 18 05:27:39 PST 2009
Jelmer,
you might want to check out Mapserver 5.6 release candidates, since WFS was greatly optimized for database sources (single pass query).
Best regards,
Bart
On Nov 18, 2009, at 2:20 PM, Jelmer Baas wrote:
> Michael,
> Thanks for the tip. Indeed, I still need to add these tags, but since my
> dataset wasn't working at all, I didn't do anything with that, yet.
> Right now the query takes 16-20sec, so some optimization is in order.
> Regards,
> Jelmer
>> Jelmer,
>> Also, when using WFS from Oracle, you should add the wfs_extent or
>> ows_extent metadata tags. Otherwise MapServer will request
>> Oracle to do a
>> convex_hull to get the extent of your data. On large
>> datasets, this can take
>> a while. Setting the extent metadata tag bypasses this check
>> and uses the
>> value you specify.
> mapserver-users at lists.osgeo.org
More information about the MapServer-users
