[mapserver-users] understanding behind the GetFeatureInfo...
    Martin Ouellet
    geomartino at gmail.com
    Thu Nov 19 06:14:06 PST 2009
Here the results of some tests I've made yesterday to really understand the
process of a GetFeatureInfo call with MapServer.  Please let me know if I'am
mistaking:
1) GetFeatureInfo with INFO_FORMAT=text/plain
Result: the tag TEMPLATE must be specify (with a dummy file).  Then you can
control the returned values with the METADATA tag
ows_<include|exclude>_items or wms_<include|exclude>_items
2) GetFeatureInfo with INFO_FORMAT=gml
Result: the tag DUMP must be set to TRUE and the TEMPLATE must be specify
(with a dummy file).  Then you can control the returned value with the
METADATA tag gml_<include|exclude>_items
3) GetFeatureInfo with INFO_FORMAT=text/html
Result: the only required tag is TEMPLATE (a dummy file will return no
data).  But if you supply a valid html template, ALL the field will be
returned because the METADATA tag ows_<include|exclude>_items
or wms_<include|exclude>_items are ignored.  So if my layer is a Oracle
spatial table, I must then create a view to expose only the field I want.
 Would it be relevant to control the field with the "wms_include_items" tag
? Is there a reason why is not working that way?
MartinOuellet
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091119/a3bb3a60/attachment.htm>
More information about the MapServer-users
