[mapserver-users] WMSGetFeatureInfo problems with OpenLayers
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Fri Nov 20 21:32:23 PST 2009
Thank you. That was the key. I have it working now.
I'll write some bugs against the docs and another issue I found tomorrow.
It looks like templates without a path are not searched for in the
SHAPEPATH which would be a logical place for at least query templates as
they are directly related to the shapefile layers they present data for.
Appreciate all the help support you provide.
Best regards,
   -Steve W
Daniel Morissette wrote:
> Stephen Woodbridge wrote:
>> And I get this response:
>> Content-type: application/vnd.ogc.se_xml
>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>> <!DOCTYPE ServiceExceptionReport SYSTEM
>> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
>> <ServiceExceptionReport version="1.1.0">
>> <ServiceException>
>> msReturnPage(): Web application error. Malformed template name
>> (parcels.hdr).
>> </ServiceException>
>> </ServiceExceptionReport>
> This error is probably related to the template filename extension
> filter: .hdr is not a valid extension. Try renaming the file to
> parcels_hdr.html.
> I believe there is a mechanism to specify a different template filename
> filter in your mapfile, but I can't remember what it is or find a ref to
> it at the moment. We could probably use better docs for this.
> Daniel
More information about the MapServer-users
