[mapserver-users] WMSGetFeatureInfo
Ir. Peter Huis in 't Veld
peterh at ivs90.nl
Sat Nov 21 15:56:28 EST 2009
I'm trying to set up a WMS service with the possibility to obtain a
popup containing the feature items.
the components I''m using is:
- Openlayer
- Mapserver
Testing it I can visualize all items but I get the following error
message :
Message: Object doesn't support this property or method
Line: 229
Char: 9
Code: 0
URI: http://myserver/lib/OpenLayers/Handler/Feature.js
Looking at the code it looks like it has something to with the
evalaution of the mouse click event
I've three questions:
- Could someone explain a bit more about this error?
- Should I stick with WMS or should I use WFS?
- Does someone has some advice what might cause a problem based on the
code snippet underneath?
Thanks in advance for any support
Peter
Within in my webpage I've some javascript looking like:
function init() {
info = {
click: new OpenLayers.Control.WMSGetFeatureInfo({
'url': 'http://cccc',
'title': 'Identify features by clicking',
'layers': "test",
'queryVisible': true
for (var i in info) {
info[i].events.register("getfeatureinfo", this, showInfo);
map.addControl(info[i]);
info.click.activate();
function showInfo(evt) {
if (evt.features && evt.features.length) {
highlightLayer.destroyFeatures();
highlightLayer.addFeatures(evt.features);
highlightLayer.redraw();
} else {
$('responseText').innerHTML = evt.text;
In mapserver I've defined the layer and all wms_... parameters
LAYER
METADATA
"wms_title" "IVS90 Stremmingen"
"wms_include_items" "all"
"wms_feature_info_mime_type" "text/html"
END
TYPE POINT
TOLERANCE 10
TOLERANCEUNITS kilometers
CLASS
TEMPLATE "template.html"
END
END
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091121/ef686bc9/peterh.vcf
