[mapserver-users] WMSGetFeautureInfo
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 21 16:28:05 EST 2009
Hi Peter,
Since I just struggle my through this exact example, I think I might be
able to help :)
Peter Huis in 't Veld wrote:
> Hi,
> I'm trying to set up a WMS service with the possibility to obtain a
> popup containing the feature items.
> the components I''m using is:
> - Openlayer
> - Mapserver
> Testing it I can visualize all items but I get the following error
> message :
> Message: Object doesn't support this property or method
> Line: 229
> Char: 9
> Code: 0
> URI: http://myserver/lib/OpenLayers/Handler/Feature.js
> Looking at the code it looks like it has something to with the
> evalaution of the mouse click event
> I've three questions:
> - Could someone explain a bit more about this error?
> - Should I stick with WMS or should I use WFS?
> - Does someone has some advice what might cause a problem based on the
> code snippet underneath?
> Thanks in advance for any support
> Peter
> Within in my webpage I've some javascript looking like:
The problem is that you need to declare you layer as a global:
var test;
> function init() {
test = = new OpenLayers.Layer.WMS( ... );
> info = {
> click: new OpenLayers.Control.WMSGetFeatureInfo({
> 'url': 'http://cccc',
> 'title': 'Identify features by clicking',
then change the next line to be:
'layers': [test],
> 'layers': "test",
I think that might fix things up for you.
-Steve W
> 'queryVisible': true
> for (var i in info) {
> info[i].events.register("getfeatureinfo", this, showInfo);
> map.addControl(info[i]);
> info.click.activate();
> function showInfo(evt) {
> if (evt.features && evt.features.length) {
> highlightLayer.destroyFeatures();
> highlightLayer.addFeatures(evt.features);
> highlightLayer.redraw();
> } else {
> $('responseText').innerHTML = evt.text;
> In mapserver I've defined the layer and all wms_... parameters
> LAYER
> METADATA
> "wms_title" "IVS90 Stremmingen"
> "wms_include_items" "all"
> "wms_feature_info_mime_type" "text/html"
> END
> TYPE POINT
> TOLERANCE 10
> TOLERANCEUNITS kilometers
> CLASS
> TEMPLATE "template.html"
> END
> END
> mapserver-users at lists.osgeo.org
