[mapserver-users] WMSGetFeautureInfo
Peter Huis in 't Veld
perico1970 at gmail.com
Sat Nov 21 17:05:56 EST 2009
Hi Steve,
The layer is already a global variable. But nevertherless I think I
found the problem based on your remark. I have used the layer name
of mapserver and not the javascript variable layer reference!
Thanks!!!
Stephen Woodbridge schreef:
> Hi Peter,
> Since I just struggle my through this exact example, I think I might
> be able to help :)
> Peter Huis in 't Veld wrote:
>> Hi,
>> I'm trying to set up a WMS service with the possibility to obtain a
>> popup containing the feature items.
>> the components I''m using is:
>> - Openlayer
>> - Mapserver
>> Testing it I can visualize all items but I get the following error
>> message :
>> Message: Object doesn't support this property or method
>> Line: 229
>> Char: 9
>> Code: 0
>> URI: http://myserver/lib/OpenLayers/Handler/Feature.js
>> Looking at the code it looks like it has something to with the
>> evalaution of the mouse click event
>> I've three questions:
>> - Could someone explain a bit more about this error?
>> - Should I stick with WMS or should I use WFS?
>> - Does someone has some advice what might cause a problem based on
>> the code snippet underneath?
>> Thanks in advance for any support
>> Peter
>> Within in my webpage I've some javascript looking like:
> The problem is that you need to declare you layer as a global:
> var test;
>> function init() {
> test = = new OpenLayers.Layer.WMS( ... );
>> info = {
>> click: new OpenLayers.Control.WMSGetFeatureInfo({
>> 'url': 'http://cccc',
>> 'title': 'Identify features by clicking',
> then change the next line to be:
> 'layers': [test],
>> 'layers': "test",
> I think that might fix things up for you.
> -Steve W
>> 'queryVisible': true
>> for (var i in info) {
>> info[i].events.register("getfeatureinfo", this, showInfo);
>> map.addControl(info[i]);
>> info.click.activate();
>> function showInfo(evt) {
>> if (evt.features && evt.features.length) {
>> highlightLayer.destroyFeatures();
>> highlightLayer.addFeatures(evt.features);
>> highlightLayer.redraw();
>> } else {
>> $('responseText').innerHTML = evt.text;
>> In mapserver I've defined the layer and all wms_... parameters
>> LAYER
>> METADATA
>> "wms_title" "IVS90 Stremmingen"
>> "wms_include_items" "all"
>> "wms_feature_info_mime_type" "text/html"
>> END
>> TYPE POINT
>> TOLERANCE 10
>> TOLERANCEUNITS kilometers
>> CLASS
>> TEMPLATE "template.html"
>> END
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
