[mapserver-users] WMSgetFeatureInfo and variable substitution
Daniel Morissette
dmorissette at mapgears.com
Mon Nov 23 13:14:32 EST 2009
I saw your post on the openlayers list, and it seems from your
description of the problem that the SEMCDC, RCC and ORDER params are
included by OpenLayers in a GetMap request but it fails to include them
in the corresponding GetFeatureInfo request. If that's the case then
that's an issue with OpenLayers, or with the way you configure your
queryable layer in OL. I'm not fluent enough in OL personally to tell
where the solution lies, but if the params are missing in the URL then
the problem is definitely on the client side and not on the server.
Daniel
Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> I already posted this problem on openlayers list, but it might be a
> mapserver issue.
> OpenLayers.Control.WMSGetFeatureInfo doesn't use the FILTER key in my
> mapfile. This filter is define with variables like this:
> FILTER "semcdc in (%SEMCDC%) and rss in (%RSS%) and ordre in (%ORDRE%)" .
> The getMap request is succesfull but not the GetFeatureInfo request
> Here is the request GetFeatureInfo
> /cgi-bin/mapserv.exe?map=MYMAP
> service=WMS&version=1.1.0&request=GetFeatureInfo&layers=ecoles&query_layers=ecoles&styles=&bbox=-8820221.560815%2C5721770.182129%2C-7587445.168853%2C6361395.234705&srs=EPSG%3A900913&feature_count=3000&x=272&y=457&height=523&width=1008&info_format=text%2Fhtml
> Here is the response
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>
> prepare_database(): Query error. Error declaring cursor: ERROR: syntax
> error at or near "%"
> LINE 1: ...:text from ecoles WHERE (semcdc in (%SEMCDC%) ...
> With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
> "taux_abs"::text,"nouv"::text,asbinary(force_collection(force_2d(geom900913)),'NDR'),id::text
> from ecoles WHERE (semcdc in (%SEMCDC%) and rss in (%RSS%) and ordre in
> (%ORDRE%)) and (geom900913 && setSRID(
> 'BOX3D(-8493071.07981319 5795761.22549582,-8480841.15528974
> 5807991.15001926)'::BOX3D,900913) )
> </ServiceException>
> </ServiceExceptionReport>
> In OL, I have a WMS layer define like this:
> new OpenLayers.Layer.WMS('ecoles',
> '.../cgi-bin/mapserv.exe?map=MYMAP',{layers: 'ecoles', transparent:
> "true", format:"image/gif", SEMCDC:thisCDC, RSS: thisRSS, ORDRE:
> thisOrdre},{isBaseLayer: false, visibility:
> false,singleTile:true,transitionEffect: 'resize'});
> How should I query the layer?
> Thanks
> Steve
> Steve Toutant, M. Sc./
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144_
> __steve.toutant at inspq.qc.ca_ <mailto:steve.toutant at inspq.qc.ca>_
> __http://www.inspq.qc.ca_ <http://www.inspq.qc.ca/>
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
