[mapserver-users] LABELS
Jose Antonio Arce
joseantonioarce at gmail.com
Mon Nov 23 14:51:42 EST 2009
Hi people, I hope you are doing well.
How can I center a label in every country of the map.
Thanks,
JOSE ARCE
from Costa Rica
mapserver-users-request at lists.osgeo.org wrote:
> Send mapserver-users mailing list submissions to
> mapserver-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapserver-users digest..."
> Today's Topics:
> 1. WMSgetFeatureInfo and variable substitution
> (Steve.Toutant at inspq.qc.ca)
> 2. Re: WMSgetFeatureInfo and variable substitution (Martin Ouellet)
> 3. Re: WMSgetFeatureInfo and variable substitution
> (Daniel Morissette)
> 4. Re: php-mapscript compilation problem on OpenSuse 11.1/11.2
> (Daniel Morissette)
> Message: 1
> Date: Mon, 23 Nov 2009 12:44:43 -0500
> From: Steve.Toutant at inspq.qc.ca
> Subject: [mapserver-users] WMSgetFeatureInfo and variable substitution
> To: mapserver-users at lists.osgeo.org
> Message-ID:
> <OF439C3E0F.A471B251-ON85257677.0060EE5B-85257677.00617AB8 at ssss.gouv.qc.ca>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> I already posted this problem on openlayers list, but it might be a
> mapserver issue.
> OpenLayers.Control.WMSGetFeatureInfo doesn't use the FILTER key in my
> mapfile. This filter is define with variables like this:
> FILTER "semcdc in (%SEMCDC%) and rss in (%RSS%) and ordre in (%ORDRE%)" .
> The getMap request is succesfull but not the GetFeatureInfo request
> Here is the request GetFeatureInfo
> /cgi-bin/mapserv.exe?map=MYMAP
> service=WMS&version=1.1.0&request=GetFeatureInfo&layers=ecoles&query_layers=ecoles&styles=&bbox=-8820221.560815%2C5721770.182129%2C-7587445.168853%2C6361395.234705&srs=EPSG%3A900913&feature_count=3000&x=272&y=457&height=523&width=1008&info_format=text%2Fhtml
> Here is the response
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM "
> http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>
> prepare_database(): Query error. Error declaring cursor: ERROR: syntax
> error at or near "%"
> LINE 1: ...:text from ecoles WHERE (semcdc in (%SEMCDC%) ...
> With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
> "taux_abs"::text,"nouv"::text,asbinary(force_collection(force_2d(geom900913)),'NDR'),id::text
> from ecoles WHERE (semcdc in (%SEMCDC%) and rss in (%RSS%) and ordre in
> (%ORDRE%)) and (geom900913 && setSRID(
> 'BOX3D(-8493071.07981319 5795761.22549582,-8480841.15528974
> 5807991.15001926)'::BOX3D,900913) )
> </ServiceException>
> </ServiceExceptionReport>
> In OL, I have a WMS layer define like this:
> new OpenLayers.Layer.WMS('ecoles',
> '.../cgi-bin/mapserv.exe?map=MYMAP',{layers: 'ecoles', transparent:
> "true", format:"image/gif", SEMCDC:thisCDC, RSS: thisRSS, ORDRE:
> thisOrdre},{isBaseLayer: false, visibility:
> false,singleTile:true,transitionEffect: 'resize'});
> How should I query the layer?
> Thanks
> Steve
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144
> steve.toutant at inspq.qc.ca
> http://www.inspq.qc.ca
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091123/423ab2c2/attachment-0001.html
> Message: 2
> Date: Mon, 23 Nov 2009 13:13:11 -0500
> From: Martin Ouellet <geomartino at gmail.com>
> Subject: Re: [mapserver-users] WMSgetFeatureInfo and variable
> substitution
> To: Steve.Toutant at inspq.qc.ca
> Cc: mapserver-users at lists.osgeo.org
> Message-ID:
> <28d70b140911231013ud4aaa69ld2e280607996714b at mail.gmail.com>
> One way to do it is to pass new parameters(with tha exact name of you're
> mapfile variable) in the GetFeatureInfo URL so it would look something like
> this:
> *&**SEMCDC=<value>&**RSS=**<value>&**ORDRE**<value>*
> MapServer will then replace the value before returning the result.
> hope's this help....
> MartinO
> 2009/11/23 <Steve.Toutant at inspq.qc.ca>
>> Hi,
>> mapserver issue.
>> <ServiceException>
>> (%ORDRE%)) and (geom900913 && setSRID( 'BOX3D(-8493071.07981319
>> 5795761.22549582,-8480841.15528974 5807991.15001926)'::BOX3D,900913) )
>> </ServiceException>
>> '.../cgi-bin/mapserv.exe?map=MYMAP',{layers: 'ecoles', transparent: "true",
>> Thanks
>> Steve
>> Steve Toutant, M. Sc.*
>> 945, avenue Wolfe
>> Québec, Qc G1V 5B3
>> Fax.: (418) 654-3144*
>> **steve.toutant at inspq.qc.ca* <steve.toutant at inspq.qc.ca>*
>> **http://www.inspq.qc.ca* <http://www.inspq.qc.ca/>
> URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091123/53823b42/attachment-0001.html
> Message: 3
> Date: Mon, 23 Nov 2009 13:14:32 -0500
> From: Daniel Morissette <dmorissette at mapgears.com>
> substitution
> To: mapserver-users <mapserver-users at lists.osgeo.org>
> Message-ID: <4B0AD108.3060307 at mapgears.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> I saw your post on the openlayers list, and it seems from your
> description of the problem that the SEMCDC, RCC and ORDER params are
> included by OpenLayers in a GetMap request but it fails to include them
> in the corresponding GetFeatureInfo request. If that's the case then
> that's an issue with OpenLayers, or with the way you configure your
> queryable layer in OL. I'm not fluent enough in OL personally to tell
> where the solution lies, but if the params are missing in the URL then
> the problem is definitely on the client side and not on the server.
> Daniel
> Steve.Toutant at inspq.qc.ca wrote:
>> Hi,
>> mapserver issue.
>> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
>> <ServiceException>
>> </ServiceException>
>> Thanks
>> Steve
>> Steve Toutant, M. Sc./
>> 945, avenue Wolfe
>> Québec, Qc G1V 5B3
>> Fax.: (418) 654-3144_
>> __steve.toutant at inspq.qc.ca_ <mailto:steve.toutant at inspq.qc.ca>_
>> __http://www.inspq.qc.ca_ <http://www.inspq.qc.ca/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091123/3619edca/attachment-0001.html
