[mapserver-users] Mapserver 5.2.1 ignores WMS requests for 	version after 1.1.1
    bartvde at osgis.nl
    bartvde at osgis.nl
    Tue Nov 24 02:38:59 PST 2009
MS 5.2.1 does not support WMS 1.3.
Try 5.4.
Best regards,
Bart
> Hi to all,
> I've just donwloaded mapserver binaries for windows (http://maptools.
> org/dl/ms4w/ms4w-2.3.1-setup.exe).
> The output of mapserv -v is:
> MapServer
> version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG
> INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I succesfully installed all
> the stuff but when I try to get a WMS 1.3.0 getCapabilities response the
> Mapservers,
> it seems to ignore the version parameter (if it is > 1.1.1).
> For
> example, if I try to get a 1.3.0 response from the embedded Gmap example
> you
> can observe that
> the response is not of type 1.3.0. Just try:
> http:
> //localhost/cgi-bin/mapserv.exe?map=C:\Program%
> 20Files\ms4w\apps\gmap\htdocs\gmap75.map&service=wms&version=1.3.0
> &request=getCapabilities
> What you'll see is that the response will contain
> something like:
> <WMT_MS_Capabilities version="1.1.1">
> Unfortunately this fact
> occurs for all maps of mine, also with the simplest one, without any
> layer! Any
> ideas?
> Best regards,
> Flavio
> mapserver-users at lists.osgeo.org
More information about the MapServer-users
