[mapserver-users] php-mapscript compilation problem on OpenSuse 	11.1/11.2
    Martin Ouellet
    geomartino at gmail.com
    Tue Nov 24 09:20:54 PST 2009
Problem solve, here's how:
For a unknown reason, the following parameter was specified to Mapserver
--without-ld-shared
Without this parameter, it work like a charm.
Thanks Daniel for your wise advise!
MartinO
2009/11/23 Martin Ouellet <geomartino at gmail.com>
> Every time I try to build I do a make distclean wich is supposed to be
> more cleaner than a make clean when available.
> here is the ouptut
> spssogl92t:/usr/src/mapserver-5.6.0-beta5/mapscript/php3 # make clean
> rm -f *.so *.o perl.out
> gcc -fPIC -g  -fPIC -Wall   -DUSE_PHP_REGEX -DCOMPILE_DL=1 -DPHP4
> -DUSE_WMS_LYR    -DUSE_CURL   -DUSE_WMS_SVR  -DUSE_ORACLESPATIAL
> -DUSE_POSTGIS  -DUSE_GDAL   -DUSE_THREAD -DUSE_PROJ -DUSE_EPPL  -DUSE_AGG
>  -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
> -DUSE_ICONV -DUSE_ZLIB  -I/usr/src/mapserver-5.6.0-beta5
> -I/opt/oracle/product/10.2/db_1//rdbms/public
> -I/opt/oracle/product/10.2/db_1//rdbms/demo
> -I/opt/oracle/product/10.2/db_1//rdbms/public  -I/usr/include/pgsql
> -I/usr/include    -I/usr/include/freetype2    -I/usr/include
> -I/usr/include/php5 -I/usr/include/php5/dl -I/usr/include/php5/main
> -I/usr/include/php5/Zend -I/usr/include/php5/include
> -I/usr/include/php5/TSRM  -I/usr/include/php5/ext/ereg/ -c -o
> php_mapscript_util.o php_mapscript_util.c
> php_mapscript.o php_mapscript.c
> php_mapscript.c: In function ‘php3_ms_map_removeLayer’:
> php_mapscript.c:6217: warning: cast from pointer to integer of different
> size
> php_mapscript.c: In function ‘_phpms_build_layer_object’:
> php_mapscript.c:6749: warning: cast from pointer to integer of different
> size
> -I/usr/include/php5/TSRM  -I/usr/include/php5/ext/ereg/ -c -o mapscript_i.o
> mapscript_i.c
> -I/usr/include/php5/TSRM  -I/usr/include/php5/ext/ereg/ -c -o php_regex.o
> php_regex.c
> /bin/true  -o php_mapscript.so php_mapscript_util.o php_mapscript.o
> mapscript_i.o php_regex.o  -L/usr/src/mapserver-5.6.0-beta5 -lmapserver
> -lcurl  -L/opt/oracle/product/10.2/db_1//lib -lclntsh  -L/usr/lib64 -lpq
> -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lkrb5 -lcom_err -lgssapi_krb5
> -lz -lreadline -lcrypt -ldl -lm   -ljpeg -lfreetype -lz -lpng -lz -lXpm
> -lX11  -L/usr/lib64 -lgdal -L/opt/oracle/product/10.2/db_1//lib -lclntsh
> -lnnz10 -L/usr/lib -lexpat -L/usr/lib64/ecwj2/lib -lNCSEcw -lNCSCnet
> -lNCSUtil -ljpeg -lpng -lnetcdf -L/usr/include/libcfitsio0
> -L/usr/include/libcfitsio0/lib -lcfitsio -lz -lm -lrt -ldl -lcurl
> -lpthread -lproj    -L/usr/lib -lgd -ljpeg -lfreetype -lz -lpng -lz -lXpm
> -lX11  -lc -lz   -lm -lstdc++
> spssogl92t:/usr/src/mapserver-5.6.0-beta5/mapscript/php3 #ls
> Makefile     Makefile.vc  README.WIN32  mapscript_i.c  nmake.opt
> php_mapscript.h  php_mapscript_util.c  php_mapscript_util.o  php_regex.c
> Makefile.in  README       examples      mapscript_i.o  php_mapscript.c
> php_mapscript.o  php_mapscript_util.h  php_proj.c            php_regex.o
> no php_mapscript.so   and no error
> MartinO
> 2009/11/23 Daniel Morissette <dmorissette at mapgears.com>
> Martin Ouellet wrote:
>>> Even with the mapserv-5.6-beta5, there's still no php_mapscript.so after
>>> the compilation.  I notice one thing, the directory
>>> "/usr/include/php5/dl" (which I see appear while the make command is
>>> running) is missing on my server.
>>> Could it be the problem?.
>>> Here's my ./configure command:
>> Everything seems okay in the configure output. Perhaps look for error
>> messages in the 'make' output. php_mapscript.so is compiled and linked
>> almost at the very end of the build.
>> Also, make sure you 'make clean' before doing 'make' everytime you change
>> your configure options.
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091124/8bf973d7/attachment.htm>
More information about the MapServer-users
