[mapserver-users] Export SVG
Maria Neywell
maria.neywell at gmail.com
Wed Nov 25 04:07:41 EST 2009
Thanks,
I have already tried this way to extract my map in a svg file and it works.
*However*, I had a svg file which corresponds to my map but with a lot of
aliasing. The FORMATOPTION "FULL_RESOLUTION=TRUE" changes nothing. I tested
this with and without option.
I don't know if I did something wrong or if this is a mapserver problem…
am I the only one to have this problem ?
Regards,
Maria
2009/11/24 Yewondwossen Assefa <yassefa at dmsolutions.ca>
> Hi,
> You could possibly specify FULL_RESOLUTION option in your outputformat.
> Something like this:
> OUTPUTFORMAT
> NAME svg
> MIMETYPE "image/svg+xml"
> DRIVER svg
> END
> best regards,
> Maria Neywell wrote:
>> Hi list,
>> I'm using mapserver 5.2.
>> I have tested all mapserver exports to render my map in svg, see :
>> http://mapserver.org/output/svg.html but, the point is that all of these
>> outputs give me up simplified geometry. I want to export my map in a svg
>> with geometries who match exactly with my map.
>> did someone noticed that same weird result ?
>> Regards,
>> Maria
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen Software Analyst
> Email: assefa at dmsolutions.ca http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091125/50be1151/attachment.html
