[mapserver-users] Cascading with virtual earth
Murty Maganti
MMaganti at oriongis.com
Wed Nov 25 12:11:05 EST 2009
Hi
I am cascading a map from map server on top of virtual earth. I want to
set the transparency for map server layer and see the features from
virtual earth map below. I tired the following but did not work. Is it
possible to do it in map file and what is the syntax?
(I am using C# map script to generate the map image and open layers to
cascade with virtual earth)
OUTPUTFORMAT
NAME "AGG"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE "RGBA"
TRANSPARENT TRUE
END
LAYER
NAME "abcd"
OPACITY 25
END
Thanks
Murty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091125/fe03dda5/attachment.html
