[mapserver-users] Black background with palette
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 30 10:35:58 EST 2009
Another thought on this is the because you are asking for a transparent
image, the IMAGECOLOR tag is usually transparent and I have seen that
come up as black in some cases.
-Steve W
Stephen Woodbridge wrote:
> Alexandre,
> Do you have IMAGECOLOR "#000000" set at the MAP level? Also I would put
> the background color as the first color in the mypalette.txt file and
> see if that helps.
> -Steve W
> Alexandre Dube wrote:
>> Hi,
>> == problem ==
>> I'm pretty sure I saw this problem on the list somewhere, but I
>> couldn't find the actual thread so here it is : while using
>> agg & palette option, when there's no data to draw, instead of having
>> the backgroundcolor drawn it's all black instead.
>> How can I go around this problem ?
>> == my actual need ==
>> I want to produce smaller images. Currently, my getMap renders a 66K
>> png image. With the palette, it's down to 17K but with a black
>> background.
>> == ouputformat definition ==
>> OUTPUTFORMAT
>> NAME aggpng24
>> DRIVER AGG/PNG
>> MIMETYPE "image/png"
>> IMAGEMODE RGB
>> EXTENSION "png"
>> FORMATOPTION "INTERLACE=OFF"
>> FORMATOPTION "PALETTE_FORCE=ON"
>> FORMATOPTION "PALETTE=/my/path/mypalette.txt"
>> TRANSPARENT ON
>> FORMATOPTION "TRANSPARENT=ON"
>> END
> mapserver-users at lists.osgeo.org
