[mapserver-users] Black background with palette
Alexandre Dube
adube at mapgears.com
Mon Nov 30 10:41:16 EST 2009
Stephen,
The MAP imagecolor isn't black and to put it at first position in my
palette file but that didn't help.
Thanks for your help,
Alexandre
Stephen Woodbridge wrote:
> Another thought on this is the because you are asking for a
> transparent image, the IMAGECOLOR tag is usually transparent and I
> have seen that come up as black in some cases.
> -Steve W
>> Alexandre,
>> Do you have IMAGECOLOR "#000000" set at the MAP level? Also I would
>> put the background color as the first color in the mypalette.txt file
>> and see if that helps.
>> -Steve W
>> Alexandre Dube wrote:
>>> Hi,
>>> == problem ==
>>> I'm pretty sure I saw this problem on the list somewhere, but I
>>> couldn't find the actual thread so here it is : while using
>>> agg & palette option, when there's no data to draw, instead of
>>> having the backgroundcolor drawn it's all black instead.
>>> How can I go around this problem ?
>>> == my actual need ==
>>> I want to produce smaller images. Currently, my getMap renders a
>>> 66K png image. With the palette, it's down to 17K but with a black
>>> background.
>>> == ouputformat definition ==
>>> OUTPUTFORMAT
>>> NAME aggpng24
>>> DRIVER AGG/PNG
>>> MIMETYPE "image/png"
>>> IMAGEMODE RGB
>>> EXTENSION "png"
>>> FORMATOPTION "INTERLACE=OFF"
>>> FORMATOPTION "PALETTE_FORCE=ON"
>>> FORMATOPTION "PALETTE=/my/path/mypalette.txt"
>>> TRANSPARENT ON
>>> FORMATOPTION "TRANSPARENT=ON"
>>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alexandre Dubé
Mapgears
www.mapgears.com
