[mapserver-users] Black background with palette
Alexandre Dube
adube at mapgears.com
Mon Nov 30 13:47:32 EST 2009
Stephen,
Everything is there : http://trac.osgeo.org/mapserver/ticket/3217
Kind regards,
Alexandre
Stephen Woodbridge wrote:
> Alexandre,
> Try this as a hack and see if it helps.
> Create a dummy LAYER like:
> LAYER
> NAME "pixel"
> STATUS DEFAULT
> TYPE POINT
> TRANSFORM OFF
> FEATURE
> POINTS 0 0 END
> END
> CLASS
> COLOR <backgroundcolor>
> END
> END
> and make it your first layer. This will draw a one pixel dot in the
> upper left corner of the image in background color, but it might fake
> out mapserver if you have it some funny corner case.
> Also can you reproduce this with a mapfile with one layer like the
> above, but with POINTS -2 -2 END so that it is drawn off the image?
> THen post you that makefile and we can try it.
> What version of mapserver?
> Otherwise if that doesn't work, maybe someone has other ideas.
> -Steve W
> Alexandre Dube wrote:
>> Stephen,
>> The MAP imagecolor isn't black and to put it at first position in my
>> palette file but that didn't help.
>> Thanks for your help,
>> Alexandre
>>> Another thought on this is the because you are asking for a
>>> transparent image, the IMAGECOLOR tag is usually transparent and I
>>> have seen that come up as black in some cases.
>>> -Steve W
>>>> Alexandre,
>>>> Do you have IMAGECOLOR "#000000" set at the MAP level? Also I would
>>>> put the background color as the first color in the mypalette.txt
>>>> file and see if that helps.
>>>> -Steve W
>>>>> Hi,
>>>>> == problem ==
>>>>> I'm pretty sure I saw this problem on the list somewhere, but I
>>>>> couldn't find the actual thread so here it is : while using
>>>>> agg & palette option, when there's no data to draw, instead of
>>>>> having the backgroundcolor drawn it's all black instead.
>>>>> How can I go around this problem ?
>>>>> == my actual need ==
>>>>> I want to produce smaller images. Currently, my getMap renders a
>>>>> 66K png image. With the palette, it's down to 17K but with a
>>>>> black background.
>>>>> == ouputformat definition ==
>>>>> OUTPUTFORMAT
>>>>> NAME aggpng24
>>>>> DRIVER AGG/PNG
>>>>> MIMETYPE "image/png"
>>>>> IMAGEMODE RGB
>>>>> EXTENSION "png"
>>>>> FORMATOPTION "INTERLACE=OFF"
>>>>> FORMATOPTION "PALETTE_FORCE=ON"
>>>>> FORMATOPTION "PALETTE=/my/path/mypalette.txt"
>>>>> TRANSPARENT ON
>>>>> FORMATOPTION "TRANSPARENT=ON"
>>>>> END
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alexandre Dubé
Mapgears
www.mapgears.com
