[mapserver-users] PGeo (Personal Geodatabases) options under Linux
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Nov 30 14:32:54 EST 2009
Chuck Jungmann wrote:
> Responding to both of your comments:
> My client regularly acquires a database of property maps from a county.
> The database is a ESRI Personal Database. An employee of my client has
> been converting this database (and others like it) to MapX files for
> running on MapXtreme (on Windows, as you observed). I understand it to
> be a rather involved process.
> On the subject of creating a shape file from the PGeo file: one of the
> layer tables has almost 200,000 records. That's just for the parcel
> outlines. I also would need to add the text labels and other outlines as
> well. That would make for an unwieldy shape file. In fact, I think
> that employee mentioned above actually does combine the shapes into 9
> MapX layers that I have been combining for display. The combined MAP
> files come to 221.3MB, and 351.6 MB for all layer files.
> I am exploring the possibility of delivering the same web application
> using open source software, including MapServer, on Linux. I was hoping
> to use the database as delivered, because it would save time and
> effort.
> Although it looked like it should have been possible to display layers
> from the PGeo file, I haven't had any luck. I have spent a lot of time
> trying to figure out if I could apply some patch, looking for
> insufficient buffers that I could lengthen, etc., but have pretty much
> come to the conclusion that using PGeo files is perhaps only feasible on
> MapServer for Windows, where there is native support for the MDB files.
> I originally asked the question because
> 1. I didn't want to give up too soon if someone has had some success
> using unixODBC and MDBTools, and
> 2. I wanted to know if making an exact copy of the PGeo tables in a
> MySQL database would allow me to use PGeo to access the layers. This
> seems feasible since both MDBTools and MySQL can be accessed through the
> ODBC layer.
> It would be nice if OGR wouldn't know the difference between MDB and
> MySQL databases because I could then run a script (that I'm working on
> now) that would run on Windows to make a restore file for MySQL to
> import the data. I hope to finish the script today or tomorrow. If it
> works as I hope, I'll report it here since it would answer the second
> question.
> Assuming success using MySQL, the first question is moot: MySQL would be
> a much more robust solution. If I can make a turnkey conversion from
> MDB to MySQL, it's really a no-brainer to abandon MDB. But I'm still
> curious, and it would be nice to document somewhere online, if it's
> possible to use PGeo files on a Linux-based MapServer.
Chuck,
Personally a little ogr2ogr script would convert the mdb layers into
shapefile layers, and then the same script could execute shptree on each
new shapefile. One of the (unannounced) results that I saw in the
recent benchmarking exercise at the FOSS4G event was how fast large
shapefiles (over 1,000,000 records) that are indexed properly are drawn
by MapServer.
So my advice is to keep it simple: use MS4W on windows, write a script
that can be executed each time your client hands you a lovely PGeo file,
and create the associated layers in a MapServer mapfile.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
