[mapserver-users] Re: Mapserver 5.3.2 configure problems
Matthew Pettis
matthew.pettis at gmail.com
Mon Nov 30 17:29:27 EST 2009
Thanks (again!) Daniel!
Installing libgd-dev (Ubuntu Hardy Heron 8.04 LTS) via aptitude did the
trick for getting the freetype and other dependencies to resolve.
However, I still get the following error (see last line -- I excised things
in common from original thread output):
matt at votevis:~/dwnld/mapserver-5.4.2$ sudo ./configure --with-freetype=/usr/
--with-gd=/usr/
checking for gcc... gcc
MapServer Version from mapserver.h: '5.4.2'
checking if pkg-config path is provided... checking for pkg-config... no
couldn't find pkg-config in default path. Please specify full path to
pkg-config if needed
configure: checking where FreeType 2.x is installed...
using libfreetype from -lfreetype -lz
configure: checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs (-DUSE_ZLIB).
configure: checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
configure: checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
configure: checking where libXpm is installed...
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
configure: checking where libiconv is installed...
checking for iconv_open in -lc... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -liconv... no
using libiconv from system libs.
libiconv found. Enabling internationalization (-DUSE_ICONV)
configure: checking for GD 2.0.16 or higher...
checking for gdFontCacheSetup in -lgd... no
configure: checking whether GD needs libiconv...
configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/. Make
sure GD 2.0.16 or higher is compiled before calling configure. You may also
get this error if you didn't specify the appropriate location for one of
GD's dependencies (freetype, libpng, libjpeg or libiconv).
But I do have these files on my system:
/usr/include/gd.h
/usr/lib/libgd.a
/usr/lib/libgd.so
I would think they would get recognized from what I provided as my
'--with-gd=/usr/' argument.
Any ideas?
Thanks again,
Matt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091130/e50b8dc7/attachment.html
