[mapserver-users] Black background with palette
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Nov 30 18:29:03 EST 2009
Are you compiling with the experimental png support?
>>> On 11/30/2009 at 12:47 PM, in message <4B141344.3040509 at mapgears.com>,
Alexandre Dube <adube at mapgears.com> wrote:
> Stephen,
> Everything is there : http://trac.osgeo.org/mapserver/ticket/3217
> Kind regards,
> Alexandre
> Stephen Woodbridge wrote:
>> Alexandre,
>> Try this as a hack and see if it helps.
>> Create a dummy LAYER like:
>> LAYER
>> NAME "pixel"
>> STATUS DEFAULT
>> TYPE POINT
>> TRANSFORM OFF
>> FEATURE
>> POINTS 0 0 END
>> END
>> CLASS
>> COLOR <backgroundcolor>
>> END
>> END
>> and make it your first layer. This will draw a one pixel dot in the
>> upper left corner of the image in background color, but it might fake
>> out mapserver if you have it some funny corner case.
>> Also can you reproduce this with a mapfile with one layer like the
>> above, but with POINTS -2 -2 END so that it is drawn off the image?
>> THen post you that makefile and we can try it.
>> What version of mapserver?
>> Otherwise if that doesn't work, maybe someone has other ideas.
>> -Steve W
>> Alexandre Dube wrote:
>>> Stephen,
>>> The MAP imagecolor isn't black and to put it at first position in my
>>> palette file but that didn't help.
>>> Thanks for your help,
>>> Alexandre
>>>> Another thought on this is the because you are asking for a
>>>> transparent image, the IMAGECOLOR tag is usually transparent and I
>>>> have seen that come up as black in some cases.
>>>> -Steve W
>>>>> Alexandre,
>>>>> Do you have IMAGECOLOR "#000000" set at the MAP level? Also I would
>>>>> put the background color as the first color in the mypalette.txt
>>>>> file and see if that helps.
>>>>> -Steve W
>>>>>> Hi,
>>>>>> == problem ==
>>>>>> I'm pretty sure I saw this problem on the list somewhere, but I
>>>>>> couldn't find the actual thread so here it is : while using
>>>>>> agg & palette option, when there's no data to draw, instead of
>>>>>> having the backgroundcolor drawn it's all black instead.
>>>>>> How can I go around this problem ?
>>>>>> == my actual need ==
>>>>>> I want to produce smaller images. Currently, my getMap renders a
>>>>>> 66K png image. With the palette, it's down to 17K but with a
>>>>>> black background.
>>>>>> == ouputformat definition ==
>>>>>> OUTPUTFORMAT
>>>>>> NAME aggpng24
>>>>>> DRIVER AGG/PNG
>>>>>> MIMETYPE "image/png"
>>>>>> IMAGEMODE RGB
>>>>>> EXTENSION "png"
>>>>>> FORMATOPTION "INTERLACE=OFF"
>>>>>> FORMATOPTION "PALETTE_FORCE=ON"
>>>>>> FORMATOPTION "PALETTE=/my/path/mypalette.txt"
>>>>>> TRANSPARENT ON
>>>>>> FORMATOPTION "TRANSPARENT=ON"
>>>>>> END
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
