[mapserver-users] Type initializer exception with C# MapScript
Daniel Walton
dgwalton at gmail.com
Fri Oct 2 10:55:02 EDT 2009
Hey guys,
I'm new to MS, and using the MS4W distribution. It was the only Windows
binary dist. I found that had C# MapScript set up. Anyway, I get the
following exception when I try to construct a mapObj:
*The type initializer for 'OSGeo.MapServer.mapscriptPINVOKE' threw an
exception.*
Anyone else out there seen this?
I have referenced mapscript_csharp.dll compiled by the MS4W folks, and here
is the properties pane in VS2008:
*Aliases: global
Copy Local: true
File Type: Assembly
Identity: mapscript_csharp
Path:
C:\Domains\Website1\ImageService\ImageService1\bin\mapscript_csharp.dll
Resolved: true
Runtime Version: v2.0.50727
Specific Version: true
Strong Name: true
Version: 1.0.3491.26938*
Here is the basic structure of my code:
private void CreateMap(string folder)
//Add a new map (based on a unique ticket string)
string mapfilename = folder + this.ticket + ".map";
string[] rasterfiles = Directory.GetFiles(folder, "*.tif",
SearchOption.AllDirectories);
string[] shapefiles = Directory.GetFiles(folder, "*.shp",
mapObj map = new mapObj(mapfilename);
//Add raster layers to the map
foreach (string rasterfile in rasterfiles)
//Call GDAL utils
string tiledrasterfile =
rasterfile.Substring(0,rasterfile.LastIndexOf(".")) + "_tiled.tif";
//Create image tiles for full raster
Shell(gdalroot + "gdal_translate"," -co TILED=YES " +
rasterfile + " " + tiledrasterfile);
//Add Overviews for various zoom levels
Shell(gdalroot + "gdaladdo", tiledrasterfile + " 2 4 8 16 32
64");
layerObj layer = new layerObj(map);
layer.connectiontype = MS_CONNECTION_TYPE.MS_RASTER;
layer.type = MS_LAYER_TYPE.MS_LAYER_RASTER;
layer.data = rasterfile;
layer.status = mapscript.MS_ON;
//Add shape layers to the map (ESRI shapefile)
foreach (string shapefile in shapefiles)
layer.connectiontype = MS_CONNECTION_TYPE.MS_SHAPEFILE;
layer.type = MS_LAYER_TYPE.MS_LAYER_POLYGON;
layer.data = shapefile;
map.save(mapfilename);
Dan Walton
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091002/1a038b26/attachment.html
