[mapserver-users] Type initializer exception with C# MapScript -
Step 2
Daniel Walton
dgwalton at gmail.com
Fri Oct 2 13:31:59 EDT 2009
More pre-apologies for the 101 type questions I'm asking here. Thanks for
the replies. You were all right, I just had to check all the dll
dependencies and copy those into my bin folder (32 dlls in all). Now I am
one inch further down the road. I can create the mapfile (text shown below),
but how to I get from mapfile to hosted WMS? I will break down the question
into the parts I can see so far (please add or subtract if I'm off):
1. Do I need to create the mapfile in a specific folder for MapServer to
'see' it?
2. Are there any other configuration files that need to be created or
edited for MapServer to expose my map via WMS?
3. Can the files in (2) be created/edited via MapScript?
4. What would be the base URL of the WMS once it's running?
Thanks again for your patience in holding my hand for these baby steps!
Mapfile currently being created at R:\Temp\A091002122006.map:
*MAP
EXTENT -1 -1 -1 -1
IMAGECOLOR 255 255 255
IMAGETYPE gif
SIZE -1 -1
STATUS ON
UNITS METERS
NAME "MS"
OUTPUTFORMAT
NAME "gif"
MIMETYPE "image/gif"
DRIVER "GD/GIF"
EXTENSION "gif"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
ALIGN CENTER
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEPATH ""
IMAGEURL ""
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
LAYER
DATA
"R:\Temp\A091002122006_output\A091002122006_PROCESS_RESULTS\AOI_1_S5_MIS_10m_20080706_EV30004214_Ortho_Basin_Indians_NIR.tif"
NAME "AOI_1_S5_MIS_10M_20080706_EV30004214_ORTHO_BASIN_INDIANS_NIR"
STATUS ON
TYPE RASTER
UNITS METERS
END
LAYER
DATA
"R:\Temp\A091002122006_output\A091002122006_PROCESS_RESULTS\AOI_1_S5_MIS_10m_20080706_EV30004214_Ortho_Basin_Indians_RATIO.tif"
NAME "AOI_1_S5_MIS_10M_20080706_EV30004214_ORTHO_BASIN_INDIANS_RATIO"
STATUS ON
TYPE RASTER
UNITS METERS
END
LAYER
DATA
"R:\Temp\A091002122006_output\A091002122006_PROCESS_RESULTS\AOI_1_S5_MIS_10m_20080706_EV30004214_Ortho_Basin_Indians_SWIR.tif"
NAME "AOI_1_S5_MIS_10M_20080706_EV30004214_ORTHO_BASIN_INDIANS_SWIR"
STATUS ON
TYPE RASTER
UNITS METERS
END
LAYER
DATA
"R:\Temp\A091002122006_output\A091002122006_PROCESS_RESULTS\AOI_1_S5_MIS_10m_20080706_EV30004214_Ortho_Basin_Indians_Hot_Spots.tif"
NAME
"AOI_1_S5_MIS_10M_20080706_EV30004214_ORTHO_BASIN_INDIANS_HOT_SPOTS"
STATUS ON
TYPE RASTER
UNITS METERS
END
LAYER
DATA
"R:\Temp\A091002122006_output\A091002122006_PROCESS_RESULTS\AOI_1_S5_MIS_10m_20080706_EV30004214_Ortho_Basin_Indians_FIRE_HIGHLIGHT.tif"
NAME
"AOI_1_S5_MIS_10M_20080706_EV30004214_ORTHO_BASIN_INDIANS_FIRE_HIGHLIGHT"
STATUS ON
TYPE RASTER
UNITS METERS
END
END*
On Fri, Oct 2, 2009 at 10:12 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
> 2009/10/2 Daniel Walton <dgwalton at gmail.com>:
> > Hey guys,
> > I'm new to MS, and using the MS4W distribution. It was the only Windows
> > binary dist. I found that had C# MapScript set up.
> Daniel,
> That's not exactly the case, you could also use the binaries available
> at this location:
> http://vbkto.dyndns.org/sdk/
> FWTools (http://fwtools.maptools.org/) should also have the C#
> bindings included.
> Anyway, I get the
> > following exception when I try to construct a mapObj:
> > The type initializer for 'OSGeo.MapServer.mapscriptPINVOKE' threw an
> > exception.
> > Anyone else out there seen this?
> > I have referenced mapscript_csharp.dll compiled by the MS4W folks, and
> here
> > is the properties pane in VS2008:
> Yes, most of the users have ever seen that, which would normally mean
> that not all of the dll-s are available to load when your application
> is running.
> Make sure all of the required dependecies (like mapscript.dll,
> libmap.dll, gdal geos dll-s etc.) are available in your executing
> directory.
> You may also use a file monitoring tool (like Sysinternals filemon) to
> identify the expected location of the files at run-time.
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091002/df028b65/attachment.html
