[mapserver-users] Help Serving Tiled Tiffs
Daniel Walton
dgwalton at gmail.com
Sat Oct 3 17:30:53 EDT 2009
Thanks to all of you who've been helping me learn the ropes. I am getting
close (I hope) to being able to serve up on-the-fly-generated remote sensing
imagery using GDAL and MS. I am using the latest MS4W distribution with GDAL
1.6. I have taken Tiff images and tiled and created overviews using Frank's
suggestions:
gdal_translate -co TILED=YES in.tif out.tif
gdaladdo out.tif 2 4 8 16 32 64
When I request an image using a web browser like:
http://localhost/cgi-bin/mapserv.exe?map=R:\Temp\Test\A091003033655.map&SERVICE=WMS&VERSION=1.1.0&REQUEST=GetMap&
SRS=EPSG:4326&BBOX=36.141921,-121.788916,36.324769,-121.565064&FORMAT=image/tiff&WIDTH=256&HEIGHT=256&STYLES=&LAYERS=TEST_SWIR_TILED
all I get is a white image. The BBOX parameter is the same as my mapfile
extents, which is the same as the imagery bounds. The projections are the
same as well (EPSG 4326).
Questions:
1. Can I pull up an image this way in a browser (using FF 3.5)
2. If so, what am I doing wrong?
3. What are some other points of validation I can perform to break down
the testing a bit more?
4. What needs to be done to be able to view the WMS images in Google
Earth or ArcGIS explorer (e.g. adding querystring arguments via a proxy
handler, etc?)
Thanks again MS community. I look forward to someday joining the ranks.
-Dan
My Mapfile looks like this:
MAP
EXTENT 36.141921 -121.788916 36.324769 -121.565064
IMAGECOLOR 255 255 255
IMAGETYPE gif
SIZE -1 -1
STATUS ON
UNITS DD
NAME "MS"
OUTPUTFORMAT
NAME "GTiff"
MIMETYPE "image/tiff"
DRIVER "GDAL/GTiff"
EXTENSION "tif"
IMAGEMODE "RGB"
TRANSPARENT FALSE
END
PROJECTION
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
ALIGN CENTER
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEPATH ""
IMAGEURL ""
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
LAYER
DATA "R:\Temp\Test\test_SWIR_tiled.tif"
NAME "TEST_SWIR_TILED"
STATUS DEFAULT
TYPE RASTER
UNITS DD
END
END
Dan Walton
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091003/cd26341c/attachment.html
