[mapserver-users] Call layer
jbloc1878 at googlemail.com
Mon Oct 5 06:49:19 PDT 2009
Thanks for the response. I am using openlayers and my map does not
appear unless layer is STATUS DEFAULT.
I call layer as follows
layer1 = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://localhost/cgi-bin/mapserv.exe?", { layers: "testlayer",
map: '/ms4w/.../data/tr00.map',
gutter: 15, minZoomLevel: 1, maxZoomLevel: 10, units:'meters' });
map.addLayer(layer1);
I only view pink tiles when STATUS ON?
Thanks
On 5 Oct 2009, at 14:40, "Fawcett, David" <David.Fawcett at state.mn.us>
wrote:
> You don’t. That is how you tell MapServer that you want to view a p
> articular layer that doesn’t have a status of default.
> In many cases, if you are viewing your map using a client like
> OpenLayers, the client does this for you.
> David.
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-
> users-bounces at lists.osgeo.org] On Behalf Of jbloc1878 at googlemail.com
> Sent: Monday, October 05, 2009 8:31 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Call layer
> Hi,
> If the status of my layer is set to ON how do I call the layer
> without adding '&layer=[layername]' on the end of the URL?
> I am viewing the map via localhost/cgi-bin/mapserv.exe?
> Cheers for any help
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091005/8a16f217/attachment.htm>
More information about the MapServer-users
