[mapserver-users] mapfile filter & variable substitution question
Jennifer Shanks
shanksje at yahoo.com
Sat Oct 10 15:47:35 EDT 2009
Thanks Brent for the quick and very helpful response. I now have my filters working as I'd like.
Regards,
Jennifer
----- Original Message ----
From: "pcreso at pcreso.com" <pcreso at pcreso.com>
To: mapserver-users at lists.osgeo.org; Jennifer Shanks <shanksje at yahoo.com>
Sent: Sat, October 10, 2009 2:11:03 PM
Subject: Re: [mapserver-users] mapfile filter & variable substitution question
Hi Jennifer,
Outside of using mapscript to parse the the variable and generate the appropriate sql, there is a simple Postgres solution. Store your "year" column as a char(4) instead of int & index it. (So "like" will work on it without casting)
Have OpenLayers return a "%" for the "ALL YEARS" selection (instead of a single year) and have your query in the mapfile use like as well as "=" as below.
Individual years will be identified with the "=" operator & all years by "like", as below, where I pass the sql both a '%' & the year '2000' as examples.
HTH,
Brent Wood
test=# create table test (id serial primary key , year char(4));
NOTICE: CREATE TABLE will create implicit sequence "test_id_seq" for serial column "test.id"
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index "test_pkey" for table "test"
CREATE TABLE
test=# insert into test values (default, '1999');
INSERT 0 1
test=# insert into test values (default, '2000');
INSERT 0 1
test=# insert into test values (default, '2001');
INSERT 0 1
test=# select * from test where year='%' or year like '%';
id | year
1 | 1999
2 | 2000
3 | 2001
(3 rows)
test=# select * from test where year='2000' or year like '2000';
id | year
2 | 2000
(1 row)
--- On Sun, 10/11/09, Jennifer Shanks <shanksje at yahoo.com> wrote:
> From: Jennifer Shanks <shanksje at yahoo.com>
> Subject: [mapserver-users] mapfile filter & variable substitution question
> Date: Sunday, October 11, 2009, 6:29 AM
> Hi,
> I have a question about using the mapfile Filter option
> with variable
> substitution. In my user interface (OpenLayers), I
> have drop down boxes
> that allow users to filter the data display based on
> selected year and
> selected category. Accordingly, I have two filters
> set up in my mapfile:
> FILTER "year = %selected_year%"
> FILTER "category=%selected_category%"
> What if the user wants to see data for all years or for all
> categories?
> Is there a way that I can submit a wildcard in my mapserv
> URL instead?
> Or is there some other way to do this? My data source
> is a PostGIS.
> Regards,
> Jennifer
