[mapserver-users] Change CLASS Expression using MapScript
Dash
jimlug at co.clackamas.or.us
Mon Oct 12 19:29:55 EDT 2009
Hey there folks,
I am banging my head against this problem for sometime now. I have a
MapFile that is set up to deliver WMS layers when requested through
OpenLayers. Within my web page I am trying to change the Class Expression
(MapScript/PHP). Below is the method I am using to gain access to the Class
and change the expression. I am performing this before I enter a body tag.
The body tag has a onload event that fires off the parameters/layers I am
using within OpenLayers and makes the call to the WMS layers within my
MapFile. Am I missing something here? I thought since I am declaring the
expression before I'm displaying the map everything would be ok. I've even
retrieved the edited expression and it should work. The only thing I can
imagine is that it has something to do with a WMS setting. Any help would
be greatly appreciated. Thanks.
<head>
</head>
<?php
$situsEnc = $_POST['home'];
$situs = urldecode($situsEnc);
$map_path="/something/other/than/dirty/socks/wms/";
$map = ms_newMapObj($map_path."schools.map");
$mafLyr = $map->getLayerByName('maf');
$mafLyr->open();
$mafClass = $mafLyr->getClass(0);
$mafClass->setExpression("('[situs]' = '" . $situs . "')");
$mafLyr->close();
<body onload=i"nit()">
<div id="map"></div>
</body>
View this message in context: http://n2.nabble.com/Change-CLASS-Expression-using-MapScript-tp3811433p3811433.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
