[mapserver-users] MapServer CGI GDAL Raster reprojection
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Oct 13 05:50:13 EDT 2009
Perhaps it would work by making "+proj=ortho +lat_0=90" as the default projection of your map by adding MAP level PROJECTION block as:
PROJECTION
"proj=ortho"
"lat_0=90"
"no_defs"
END
If you want to get the image through WMS I suppose you should give it your own EPSG number and add corresponding line to epsg file, just like it has been done with EPSG:900913.
-Jukka Rahkonen-
> Heiko Schröter wrote:
> Hi,
> is there a small howto recipe of how to reproject Raster
> Images via MapServer (CGI call) with the Gdal Lib ?
> I need to go from EPSG:4326 to "+proj=ortho +lat_0=90" (Polar
> View) and i cannot figure out how to pass the Projection.
> The output image stays in EPSG:4326.
> This is not a proj4 issue. WMS calls for vector maps to be
> reprojected are ok (in a different scenario).
> Any pointer to some infos or sample code are highly appreciated.
> Thanks and Regards
> Heiko
> Reprojecting with gdalwarp works fine:
> gdalwarp -of GTiff -s_srs "epsg:4326" -t_srs "+proj=ortho
> /usr/lib/cgi-bin/mapserv -v
> MapServer version 5.4.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=THREADS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> The Test mapfile:
> MAP
> NAME WELT
> CONFIG "MS_ERRORFILE" "/tmp/ms_raster_error.txt"
> DEBUG 5
> STATUS ON
> SIZE 800 400
> IMAGETYPE PNG24
> IMAGECOLOR 240 240 240
> SHAPEPATH "data"
> EXTENT -180 -90 180 90
> UNITS DD
> WEB
> IMAGEPATH "images"
> IMAGEURL "images"
> MINSCALE 50000
> MAXSCALE 400000000
> METADATA
> # "wms_title" "Example WMS Server"
> # "wms_onlineresource"
> "http://kahlo1/cgi-bin/mapserv?map=heiko5.map&"
> "wms_srs" "ortho epsg:4326 epsg:900913"
> # or 'proj=ortho' doesn't matter
> END
> END
> LAYER
> NAME "Bild"
> DATA "/home/schroete/sciadaten/raster_test/wmap_work.png"
> TYPE RASTER
> STATUS ON
> PROJECTION
> "proj=ortho"
> END
> END
> END
> The MapServer Test call:
> /usr/lib/cgi-bin/mapserv -nh
> 'QUERY_STRING=MAP=/home/schroete/sciadaten/raster_test/raster.
> map&LAYERS=Bild&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&FOR
MAT=image/png&SRS=ortho&mode=map' > out.png
> Debug output:
> [Tue Oct 13 10:29:35 2009].656759 msDrawRasterLayerLow(Bild):
> entering.
> [Tue Oct 13 10:29:35 2009].845281 msDrawMap(): Layer 0
> (Bild), 0.189s [Tue Oct 13 10:29:35 2009].845376 msDrawMap():
> Drawing Label Cache, 0.000s [Tue Oct 13 10:29:35 2009].845397
> msDrawMap() total time: 0.193s [Tue Oct 13 10:29:35
> 2009].958674 msSaveImage() total time: 0.113s [Tue Oct 13
> 10:29:35 2009].958837 mapserv request processing time
> (loadmap not incl.): 0.307s [Tue Oct 13 10:29:35 2009].958856
> msFreeMap(): freeing map at 0x1729dc0.
> !!! NEUE TELEPHONNUMMER !!!
> !!! NEW PHONE NUMBER !!!
> Dipl.-Ing. Heiko Schröter
> Institute of Environmental Physics (IUP) phone:
> ++49-(0)421-218-62092
> Institute of Remote Sensing (IFE) fax:
> ++49-(0)421-218-4555
> University of Bremen (FB1)
> P.O. Box 330440 email:
> schroete at iup.physik.uni-bremen.de
> Otto-Hahn-Allee 1
> 28359 Bremen
> Germany
> mapserver-users at lists.osgeo.org
