VS: [mapserver-users] MapServer CGI GDAL Raster reprojection
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Oct 13 06:30:32 EDT 2009
Hi
The projection of your Bild layer is
PROJECTION
"proj=ortho"
END
I am not familiar with ortho projection, but are you sure that this is enough? In your gdalwarp example you are using also "lat_0=90".
There is no difference in reprojecting raster or vector data. This is a working example of one orthophoto layer:
METADATA
"wms_title" "orthophotos 92-96"
"wms_srs" "EPSG:2393 EPSG:3067 EPSG:4326 EPSG:900913"
END
PROJECTION
"init=epsg:2393"
END
-Jukka-
Heiko Schröter wrote:
> Am Dienstag 13 Oktober 2009 11:50:13 schrieben Sie:
> Hello,
> sorry, no that doesn't work. I have tried with epsg:3575
> (wich is somewhat polar and recognized by GDALWARP) but that
> fails as well.
> Does anyone has a working example for reprojecting raster
> images via gdallib ?
> Regards
> Heiko
> > Hi,
> > Perhaps it would work by making "+proj=ortho +lat_0=90" as
> the default projection of your map by adding MAP level
> PROJECTION block as:
> > PROJECTION
> > "proj=ortho"
> > "lat_0=90"
> > "no_defs"
> > END
> > If you want to get the image through WMS I suppose you
> should give it your own EPSG number and add corresponding
> line to epsg file, just like it has been done with EPSG:900913.
> > -Jukka Rahkonen-
> > > Hi,
> > > is there a small howto recipe of how to reproject Raster
> Images via
> > > MapServer (CGI call) with the Gdal Lib ?
> > > I need to go from EPSG:4326 to "+proj=ortho +lat_0=90" (Polar
> > > View) and i cannot figure out how to pass the Projection.
> > > The output image stays in EPSG:4326.
> > > This is not a proj4 issue. WMS calls for vector maps to be
> > > reprojected are ok (in a different scenario).
> > > Any pointer to some infos or sample code are highly appreciated.
> > > Thanks and Regards
> > > Heiko
> > > Reprojecting with gdalwarp works fine:
> > > gdalwarp -of GTiff -s_srs "epsg:4326" -t_srs "+proj=ortho
> > > /usr/lib/cgi-bin/mapserv -v
> > > MapServer version 5.4.0-rc1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > > OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> > > SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> > > SUPPORTS=THREADS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > INPUT=SHAPEFILE
> > > The Test mapfile:
> > > MAP
> > > NAME WELT
> > > CONFIG "MS_ERRORFILE" "/tmp/ms_raster_error.txt"
> > > DEBUG 5
> > > STATUS ON
> > > SIZE 800 400
> > > IMAGETYPE PNG24
> > > IMAGECOLOR 240 240 240
> > > SHAPEPATH "data"
> > > EXTENT -180 -90 180 90
> > > UNITS DD
> > > WEB
> > > IMAGEPATH "images"
> > > IMAGEURL "images"
> > > MINSCALE 50000
> > > MAXSCALE 400000000
> > > METADATA
> > > # "wms_title" "Example WMS Server"
> > > # "wms_onlineresource"
> > > "http://kahlo1/cgi-bin/mapserv?map=heiko5.map&"
> > > "wms_srs" "ortho epsg:4326 epsg:900913"
> > > # or 'proj=ortho' doesn't matter
> > > END
> > > END
> > > LAYER
> > > NAME "Bild"
> > > DATA "/home/schroete/sciadaten/raster_test/wmap_work.png"
> > > TYPE RASTER
> > > STATUS ON
> > > PROJECTION
> > > "proj=ortho"
> > > END
> > > END
> > > END
> > > The MapServer Test call:
> > > /usr/lib/cgi-bin/mapserv -nh
> > > 'QUERY_STRING=MAP=/home/schroete/sciadaten/raster_test/raster.
> > > map&LAYERS=Bild&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&FOR
> > MAT=image/png&SRS=ortho&mode=map' > out.png
> > > Debug output:
> > > [Tue Oct 13 10:29:35 2009].656759 msDrawRasterLayerLow(Bild):
> > > entering.
> > > [Tue Oct 13 10:29:35 2009].845281 msDrawMap(): Layer 0 (Bild),
> > > 0.189s [Tue Oct 13 10:29:35 2009].845376 msDrawMap():
> > > Drawing Label Cache, 0.000s [Tue Oct 13 10:29:35 2009].845397
> > > msDrawMap() total time: 0.193s [Tue Oct 13 10:29:35
> > > 2009].958674 msSaveImage() total time: 0.113s [Tue Oct 13
> > > 10:29:35 2009].958837 mapserv request processing time
> (loadmap not
> > > incl.): 0.307s [Tue Oct 13 10:29:35 2009].958856
> > > msFreeMap(): freeing map at 0x1729dc0.
