[mapserver-users] mapserver produces interlaced PNGs even if I
configured the map to output noninterlaced PNGs
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Oct 14 09:36:22 EDT 2009
Hello all,
My goal is to setup tilecache (which is proving to be a real pain), and
so far I've noticed that even if I configured my map to generate
noninterlaced PNGs (instructions here:
http://www.mapserver.org/faq.html#why-doesn-t-pil-python-imaging-library-open-my-pngs),
it still generates interlaced PNGs.
Here is my outputformat (the only one defined) in my map:
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGBA
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
END
The parameters that get sent to my mapserver instance are:
BBOX |2896046.12635,5831228.011975,2935181.884825,5870363.77045|
EXCEPTIONS |application/vnd.ogc.se_inimage|
FORMAT |png|
HEIGHT |256|
LAYERS
|Judete,RuralSate,Rural,Urban,roads,roads-buc,buildings,GranitaJudete|
MAP |/var/www/html/map/rtc_base.map|
MAP_IMAGETYPE |agg|
MAXEXTENT |left-bottom=(20.26,43.16) right-top=(29.7,48.46)|
MAXRESOLUTION |156543|
REQUEST |GetMap|
SERVICE |WMS|
SRS |EPSG:900913|
STYLES
TRANSITIONEFFECT |resize|
TRANSPARENT |false|
UNITS |m|
VERSION |1.1.1|
WIDTH |256|
I'm not sure if MAP_IMAGETYPE=agg is the one which selects the
outputformat or not, but the map seems to be rendered with AGG (I could
be wrong, of course).
So, what am I missing here? Is there another parameter that should be
sent to mapserver to select the outputformat?
By the way, the image file generated has these properties: img.png: PNG
image, 256 x 256, 8-bit colormap, interlaced
Thanks,
Adrian
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091014/30c28bb3/attachment.html
