[mapserver-users] Tileindex of DGN files
TA
useintowngas at gmail.com
Thu Oct 15 22:09:15 EDT 2009
Dear Frank Warmerdam,
> type line
> connectiontype OGR
> tileindex "/MAP/dgnindex.shp"
> data "elements"
> filter "where level = 1,2,3"
The error caused by this code is long:
msDrawMap(): Image handling error. Failed to draw layer named 'Trn'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `Trn'.
File not found or unsupported format. msConnPoolRegister(): General error
message. Missing CONNECTION on layer DGN. msConnPoolRegister(): General
error message. Missing CONNECTION on layer DGN. msConnPoolRegister():
General error message. Missing CONNECTION on layer DGN.
msConnPoolRegister(): General error message. Missing CONNECTION on layer
DGN. msConnPoolRegister(): General error message. Missing CONNECTION on
layer DGN. msConnPoolRegister(): General error message. Missing CONNECTION
on layer DGN. msConnPoolRegister(): General error message. Missing
CONNECTION on layer DGN. msConnPoolRegister(): General error message.
Missing CONNECTION on layer DGN. msConnPoolRegister(): General error
>The above should work to select only features from the DGN files with
>the desired attribute. Note that this filter will be applied to the
>files pointed to by dgnindex.shp, not to the tileindex itself.
I think so. I found that the .dbf of the tileindex shape file has only a
field "location" which stores the paths of the datafiles. Since 'data' and
'filter' work with a single DGN file, so I try to convert the tileindex
shape file to DGN and test whether filter function can be used with
tileindex DGN. I think this makes the attributes would match between
tileindex file and DGN files.
>I'm not clear what you actually did here to get this error. If you
>provide an exact commandline I might be able to look into it.
Here are the commandlines:
c:\ms4w\Apache\cgi-bin\ogrtindex -f "DGN" D:\ms4w\DGN\index.DGN
D:\ms4w\DGN\*.lpn
This gives an error of
> Error 6: CreateField<> not supported by this layer
> Can't find LOCATION field in tile index dataset.
Since it cannot find LOCATION Field, I try:
c:\ms4w\Apache\cgi-bin\ogrtindex -f "DGN" -tileindex "level"
D:\ms4w\DGN\index1.DGN D:\ms4w\DGN\*.lpn
The DGN created shows blank squares, which each square should render 1 DGN
map. That means the squares are right in coordinates but it is empty. I also
try replace "level" with DGN attributes like type, grapchicgroup and
colorindex but same result comes out.
If replacing with "elements", this would show > Can't find elements field
in tile index dataset.>
>you would use 'TYPE TILEINDEX' if you want to manage the tileindex itself
>as a distinct layer. To the best of my knowledge type tileindex layers
>do not draw. You would need another TYPE LINE layer that references the
>tileindex layer as it's tileindex instead of pointing directly to a
shapefile.
>This would allow you to apply a filter to the tileindex instead of the
>underlying files if that is your objective.
You mean one layer specfies type tileindex and another specfies type line
with tileindex "layername"?
I have tried the following code:
Layer
Name "index"
Type tileindex
#Connectiontype OGR
data "/MAP/dgnindex.shp"
END
Layer
Name "DGN"
status default
Type line
#connectiontype OGR
tileindex "index"
styleitem "auto"
class
style
color 255 0 0
end
end
END
This gives msTiledSHPOpenFile(): Shapefile error. Unable to open a single
tile to use as a template in layer LPpipe. msShapefileOpen(): Unable to
access file.(/MAP/xxx.lpn)....
If I use connectiontype OGR, the error would be like the top long
error(msDrawMap(): Image handling error.....). For this method, I have no
idea about how to connect to and render a index shp file containing DGN.
>The approach at the top should have worked.
You mean the part > tileindex "/MAP/dgnindex.shp" > data "elements" ?
Best Regards,
TA
View this message in context: http://n2.nabble.com/Tileindex-of-DGN-files-tp3820288p3833208.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
