[mapserver-users] Changing WMS Styles on the FLy
Bill Thoen
bthoen at gisnet.com
Sat Oct 17 14:03:01 EDT 2009
Guillaume Sueur wrote:
> What you can do is build a default SLD file (generated from your mapfile
> settings, mapscript has got functions for that), allow its edition on
> the client side (modification of fill and stroke colors for instance),
> and save it back to a temp (or not) location, with a specific name. Then
> send getMap again with SLD parameter pointing to that new SLD file. Note
> that the sld file must be accessible for mapserver with http.
Thanks for the quick response, Guillaume. I'm aware of mapscript's
ability to automatically generate SLD file for existing layers, but I've
got to fix my version of mapscript before I can try that. Your point
about access permissions is well-taken though; I had forgotten that
subtle, but critical, fact.
As it turned out, my problem was more fundamental. In the SLD
documentation (http://www.mapserver.org/ogc/sld.html) the example GetMap
Request leaves out several required parameters, which also generates an
unhelpful "Something went wrong" error message. I finally realized that
a GetMap request requires BBOX, SRS, WIDTH,... etc. parameters, and that
I hadn't specified them. Once I fixed that dumb mistake, it worked just
fine. Moral is, don't believe everything you read.
One question I still have though... GetMap returns an image, but I don't
know how to get it in my map window yet. I can adjust the 1:1 aspect
ratio to match my BBOX and map window aspect ratio, but how do I update
a particular layer with SLD and keep it in my map?
- Bill Thoen
GISnet - www.gisnet.com
303-786-9961
