[mapserver-users] Problem with libjpeg
Alan Hale
alan.hale at btclick.com
Mon Oct 19 10:01:45 EDT 2009
Many thanks Andy
I had already determined (I'm sorry I wasn't clear) that libjpeg.so.7
was present in /usr/local/lib/ and tried config
--with-jpeg=/usr/local/lib/ and still got the same error. The .h files
are in both /usr/include/ and /usr/local/include/
ldconfig is new to me and I get "command not found" on my system (CentOS
5 by the way).
/etc/ld.so.conf just has one line to include ld.so.conf.d/*.conf and
when I look in ld.so.conf.d there is only one file: mysql-i386.conf
Due to my inexperience, I'm sure, I remain very confused.
Thanks again
Alan
Andy Colson wrote:
> First you need to find libjpeg. one way is:
> ldconfig -v|grep jpeg
> if not there, try a few common places:
> ls /usr/lib/libjpeg*
> ls /usr/local/lib/libjpeg*
> or if you have locate/slocate then try:
> slocate libjpeg.so.7
> Second, if it seemed to compile ok, then it found the .h files (which
> are probably in /usr/include or /usr/local/include), but when you run
> it, its looking for libjpeg.so, and specifically, libjpeg.so.7 which
> is probably a symlink.
> My guess is the lib is in /usr/local/lib, but you dont have that lib
> in /etc/ld.so.conf.
> Probably just need to add that path to the file and then run ldconfig
> once.
> -Andy
> __________ Information from ESET Smart Security, version of virus
> signature database 4521 (20091019) __________
> The message was checked by ESET Smart Security.
> http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 4522 (20091019) __________
http://www.eset.com
