[mapserver-users] Tiled PNG doesn't work for WCS (and WMS)
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 20 11:20:15 EDT 2009
Steve Lime wrote:
> Be interested to hear if the soon-to-be released MapServer 5.6 fares any better speedwise. 5.0.2
> is pretty darn old. -Steve
Folks,
I believe much of the performance problem is that some versions of
GDALOpen() do a scan of the whole directory as part of the file opening
process. In a directory, like Steven's, with 60000 tiles (120000 files!)
that becomes a significant performance problem. I have suggested a
configuration item that might disable this depending on his version of
GDAL.
I also noted that Steven's tiles are 1500x1500 pngs which is a pretty
crappy thing to serve web maps from. MapServer and GDAL essentially
need to completely decode each PNG touched by a map request. To it's
credit I believe GeoServer does some smart caching that helps if there
is any locality of requests.
I've also briefed Steven on use of shptree to build a spatial index on
his spatial index.
Anyways, my point is that the performance issues are not necessarily at
the MapServer level.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
