[mapserver-users] Tiled PNG doesn't work for WCS (and WMS)
Steven M. Ottens
steven.ottens at geodan.nl
Tue Oct 20 12:29:38 EDT 2009
I got the latest FWTools and copied it's entire bin directory to a
new folder in cgi-bin (traumatizing FrankW in the process) and tested
the same data with Mapserver 5.6beta4.
It is indeed faster, but Frank pointed out that with this insane copy
action I also got the latest and greatest gdal.
So all in all, mapserver 5.6beta4 together with the new gdal is
faster than 5.0.2 and gdal1.5. In a non-scientific test I got it up
to 15x faster. (10.79s vs .694s)
Regards
Steven
On Oct 20, 2009, at 5:00 PM, Steve Lime wrote:
> Be interested to hear if the soon-to-be released MapServer 5.6
> fares any better speedwise. 5.0.2
> is pretty darn old. -Steve
>>>> On 10/20/2009 at 9:52 AM, in message
> <8225C3E9-81AB-48BA-8612-35A03B9BF19B at geodan.nl>, "Steven M. Ottens"
> <steven.ottens at geodan.nl> wrote:
>> Hi all,
>> Thanks to Frank the problem was drilled down to the way the relative
>> paths where defined in the index shapefile. Using absolute paths in
>> gdaltindex did the trick.
>> Unfortunately Geoserver 1.7.6 is faster on the same machine, with the
>> same dataset as Mapserver 5.0.2 :(
>> http://bit.ly/W02ka
>> vs
>> http://bit.ly/2sXA68
>> Thanks for all the help
>> Steven
>> On Oct 20, 2009, at 12:34 PM, Milo van der Linden wrote:
>>> Steven,
>>> - tiled png should not be a problem, I use that often.
>>> - It would be good to also set "wms_extent" in your layer defs
>>> - I think that setting the wcs_srs to multiple srs-es at the Layer
>>> Level
>>> is not how it should be done. Use a single srs there that
>>> corresponds to
>>> the wcs_extent or I guess you will have issues. Set the multiple
>>> srs-es
>>> at the wcs_srs and wms_srs on the *MAP* level
>>> Good luck! And send my regards to Mvexel ;-)
>>> Steven M. Ottens schreef:
>>>> Hi all,
>>>> I'm trying to setup a WCS with a series of PNGs with world files.
>>>> I've
>>>> indexed them with gdaltindex.
>>>> When I do a WCS getCoverage or a WMS getMap request I get a white
>>>> image. However when I configure mapserver to use only one tile as
>>>> datasource I get an image (black and white in WCS, color in WMS).
>>>> Working singletile datasource WMS: http://bit.ly/smpyA
>>>> Working singletile datasource WCS: http://bit.ly/1hXghB
>>>> not working tiled datasource WMS: http://bit.ly/2k5J11
>>>> I'm running Mapserver 5.0.2 on windows
>>>> I've tried to convert the PNGs to geotiff, but that didn't matter.
>>>> I've tried using Geoserver and there it does work, so the data
>>>> appears
>>>> to be correct.
>>>> Does mapserver support tiled PNGs?
>>>> Does it support it for WCS?
>>>> Regards,
>>>> Steven
>>>> The configuration for the two layers::
>>>> single tiledatasource:
>>>> LAYER
>>>> NAME vec200tile
>>>> METADATA
>>>> "wcs_label" "Swiss Topo Vec200 rendering for Tripod"
>>>> ### required
>>>> "wcs_rangeset_name" "Vector200Range" ###
>>>> required
>>>> to support DescribeCoverage request
>>>> "wcs_rangeset_label" "Vec200" ### required to
>>>> "wcs_extent" "463179.500000 44100.500000
>>>> 853179.500000 324100.500000" ### required for tiled datasets
>>>> [MVEXEL]
>>>> "wcs_res" "1 1" ### from gdalinfo,
>>>> undocumented metadata element
>>>> "wcs_size" "10000 10000" ### from
>>>> gdalinfo, undocumented metadata element
>>>> "wcs_srs" "EPSG:21781 EPSG:3035"
>>>> END
>>>> EXTENT 463179.500000 44100.500000 853179.500000 324100.500000
>>>> TEMPLATE "blank.html"
>>>> TYPE RASTER
>>>> UNITS METERS
>>>> STATUS ON
>>>> data "RT_Vec200_1500/1.0/vec200_1500_0_108.png"
>>>> PROJECTION
>>>> "init=epsg:21781"
>>>> END
>>>> DUMP TRUE ### required
>>>> END
>>>> tiled datasource:
>>>> LAYER
>>>> NAME vec200
>>>> METADATA
>>>> ### required
>>>> required
>>>> [MVEXEL]
>>>> "wcs_srs" "EPSG:27181 EPSG:3035"
>>>> END
>>>> TYPE RASTER
>>>> UNITS METERS
>>>> STATUS ON
>>>> TILEINDEX RT_Vec200_1500/1.0/sh1.0.shp
>>>> TILEITEM "filename"
>>>> PROJECTION
>>>> "init=epsg:21781"
>>>> END
>>>> END
Steven M. Ottens -==- http://research.geodan.nl/
