[mapserver-users] Shapefiles with islands
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Oct 21 05:54:26 EDT 2009
My comments:
- Lakes in OSM data are in a very bad shape. Tagging habits and "multipolygon" relation thing do not work well at least with big lakes with islands.
- Maybe because the tagging of lakes and islands is not standardized the data extracts, for example "waters" in Cloudmade shapefiles, are close to useless. I have looked only shapefiles of Finland but I guess that situation is the same with data from Sweden.
- Have a look at OSM building polygons which are also multipolygon relations. Mapserver is drawing them fine. At least it does so for me with the set-up described here: http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
- I think that problem is in the OSM lake data and/or Cloudmade extracts, not in Mapserver.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Lars Westerlind
> Lähetetty: 21. lokakuuta 2009 8:33
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: SV: [mapserver-users] Shapefiles with islands
> So,
> How is the lack of response to be interpreted? Nobody render
> islands in lakes? Everybody make their own data extracts? Or
> there are other (for me) hidden sources of information?
> /Lars
> -----Ursprungligt meddelande-----
> Från: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] För Lars Westerlind
> Skickat: 19 October 2009 11:43
> Till: mapserver-users at lists.osgeo.org
> Ämne: [mapserver-users] Shapefiles with islands
> Hi,
> I wonder if anyone renders islands in lakes? I use
> OpenStreetMap Data, where lakes are tagged as multipolygons,
> with islands as inner polygons.
> The source I use, mainly the "Mapserver recommended"
> cloudmade make simple extracts where those inner polygons are
> simply skipped, AFAIU.
> Looks rather funny for islands that are large enough to keep
> some roads...
> So, what is recommended? Should I make my own OpenStreetMap
> extracts for this purpose? Or does anyone have any other good
> sources?
> BTW,
> Do I understand correctly that multipolygon files must be
> converted in order to be possible to handle by mapserver? I
> mean, inner polygons should have at least an extra column in
> the DBfile, telling it's level, or such?
> Regards,
> Lars
