[mapserver-users] Any ways to increase performance of Mapserver?
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Oct 21 08:51:54 EDT 2009
Hello again,
I've compiled mapserver with fast cgi support and I've installed fastcgi
on my apache. All seems ok, but I'm not sure if mapserver runs as
fastcgi! I followed the instructions from here:
http://mapserver.org/optimization/fastcgi.html
Here's what I've added in the configuration:
in httpd.conf (Apache2):
LoadModule fastcgi_module modules/mod_fastcgi.so
<IfModule mod_fastcgi.c>
AddHandler fastcgi-script .fcgi
FastCgiIpcDir /tmp/fastcgi
FastCgiConfig -initial-env PROJ_LIB=/usr/share/proj -initial-env
LD_LIBRARY_PATH=/usr/lib:/usr/local/lib:/usr/local/pgsql/lib
-appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 2
-maxClassProcesses 30 -startDelay 5
</IfModule>
When httpd restarts, I get in the logs that fastcgi starts ok:
[Wed Oct 21 15:43:04 2009] [notice] FastCGI: process manager initialized
(pid 12570)
I think I should somehow link mapserv to fastcgi - because I see no
obvious connection. The script handler is only for .fcgi, but
mapserver's compilation didn't generate any fcgi files... It seems to
me, mapserver still runs as a cgi process. If I list the running
processes when there are no queries to the webserver, there is no
mapserv process. When I list the processes while doing queries, there
are several mapserv processes running.
Thanks,
Adrian
Adrian Popa wrote:
> Thanks,
> I'm compiling mapserver with fast-cgi support and see how that works out.
> Any idea if there is a difference in terms of speed if I make normal
> CGI queries vs WMS queries?
> Regards,
> Adrian
> Pavel Iacovlev wrote:
>> Fast-cgi is one process that manages all your connections (acts more
>> like apache module) cgi creates a new process for every connection so
>> fast-cgi is faster and consumes less resources.
>> The best performance you should get with tilecache serving TMS(If it's
>> supported by your client, openlayers supports it), images are request
>> directly so there is almost no overhead
>> On Wed, Oct 21, 2009 at 10:42 AM, Adrian Popa
>> <adrian_gh.popa at romtelecom.ro> wrote:
>>> Hello, sorry for this noobie question, but I have been running mapserver as
>>> a cgi process and sometimes I need to make lots of calls to it to get the
>>> data I want. I have used TileCache to get the layers I need and which don't
>>> change over time and it speeds things up considerably.
>>> I was wondering - is it possible (and is it more efficient?) to run
>>> mapserver as fast-cgi? Would it increase speed? The mapserver in the cgi-bin
>>> directory is already a binary file - so I'm not sure if fast-cgi would do
>>> any good.
>>> Also, would I have any extra speed benefits if I make WMS queries instead of
>>> regular cgi queries?
>>> Thank you,
>>> Adrian
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091021/658d81fe/attachment.html
