SV: [mapserver-users] roadlines issue
Lars Westerlind
lars.westerlind at enera.se
Thu Oct 22 04:50:17 EDT 2009
That's how I did it, and it works well for me. The one with all 6 different types of roads also (I think) appreciates the indexing suggested. If I understand correctly it makes it even easier for Mapserver to pick the small amount of roads visible at your pictures. The one with 4 will be much smaller (We are speaking about only motorways to primary roads, and they are not many), so it works rather well also without extra indexing. But I'm no expert.
/Lars
-----Ursprungligt meddelande-----
Från: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] För Raivo Alla
Skickat: 22 October 2009 07:47
Till: Pavel Iacovlev; mapserver-users at lists.osgeo.org
Ämne: Re: [mapserver-users] roadlines issue
Thank you, a good point!
However, this simplyfied example is for 3 layers, actually there is
about 8 layers and some of them are showing up
a little bit later (not in that scale range). So I guess the best
would be to create separate shapes based on scale ranges, ie 1:50000
to 1:24000 the map will show 4 different types of roads from one
shapefile and from 1:24000 to 1:10000 6 different types of roads from
another shape?
Raivo
On Wed, Oct 21, 2009 at 4:52 PM, Pavel Iacovlev
<iacovlev.pavel at gmail.com> wrote:
> Yes http://mapserver.org/optimization/vector.html this is described
> correctly but it's not your case because you are NOT filtering SOME of
> the data you just read ALL the data from 2 layers. I sort if you use
> ALL the data from that layer there is no point in splitting.
> On Wed, Oct 21, 2009 at 2:30 PM, Raivo Alla <snaperski at gmail.com> wrote:
>> Hey,
>> thank You. I was thinking that pre-splitting large datasets would be a
>> good optimization
>> step as suggested here: http://mapserver.org/optimization/vector.html
>> Have to try and compare ;)
>> Raivo
>> On Wed, Oct 21, 2009 at 11:45 AM, Pavel Iacovlev
>>> First if you have 2 layers for roads like highways.shp and
>>> secondary.shp (for example) if you make one shape roads.shp file with
>>> the a field "type" performance will actually improve.
>>> You can see a great example how to render street data (openstreetmap
>>> data in this case) here:
>>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
>>> On Wed, Oct 21, 2009 at 10:16 AM, Raivo Alla <snaperski at gmail.com> wrote:
>>>> Hello,
>>>> the problem I have right now with mapserver is how to display roads
>>>> that must be displayed from different layers in a mapfile,
>>>> but should have nice joining with each other. Problem is shown here
>>>> (red arrows):
>>>> http://picasaweb.google.com/snaperski/Ort#5394941894576868946
>>>> Desired situation with using multiple mapserver layers is marked with red ring.
>>>> If I would use just one massive shapefile and take it as a datasource
>>>> in one layer only (instead using multiple shapefiles/layers
>>>> drawing highways, streets), then performance will suffer.
>>>> Is there any solution to this, ie declaring DATA kayword in a CLASS
>>>> section? :) Or something so simple that I couldnt think of...
>>>> Humbly yours,
>>>> Raivo
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> http://iap.md, The future is open
