[mapserver-users] Re: Print template and WMS
Ruby
minerdiggins at gmail.com
Thu Oct 22 16:01:23 EDT 2009
Wow I'd missed the esc in the documentation! Thanks for the tip Steve.
Unfortunatly that failed to invoke the WMS layer.
Here is the returned URL:
http:/localhost:8888/cgi-bin/mapserv?map=/Applications/MAMP/d/DATA/custom.map&mapext=-112.609423+33.893223+-112.575663+33.918463&layers=BLM+Claim+Names+Washes+Roads&map_web=TEMPLATE+pgs/print.html&mapsize=1500+1182
Here is ms_error.txt for the above:
[Thu Oct 22 12:40:30 2009].462769 msDrawRasterLayerLow(Dem): entering.
[Thu Oct 22 12:40:33 2009].204991 msDrawMap(): Layer 1 (Dem), 2.743s
[Thu Oct 22 12:40:33 2009].250825 msDrawMap(): Layer 12 (Washes), 0.046s
[Thu Oct 22 12:40:33 2009].273305 msDrawMap(): Layer 25 (roads1), 0.022s
[Thu Oct 22 12:40:33 2009].331504 msDrawMap(): Layer 26 (Roads), 0.058s
[Thu Oct 22 12:40:33 2009].331789 msDrawMap(): Layer 31 (mtrq), 0.000s
[Thu Oct 22 12:40:33 2009].331833 msDrawMap(): Layer 32 (elfeet), 0.000s
[Thu Oct 22 12:40:33 2009].331911 msDrawMap(): Layer 33 (copyright), 0.000s
[Thu Oct 22 12:40:33 2009].332068 msDrawMap(): Layer 34 (compass), 0.000s
[Thu Oct 22 12:40:34 2009].5448 msDrawMap(): Drawing Label Cache, 0.673s
[Thu Oct 22 12:40:34 2009].5598 msDrawMap() total time: 3.668s
[Thu Oct 22 12:40:36 2009].749263 msSaveImage() total time: 2.744s
[Thu Oct 22 12:40:37 2009].37001 msSaveImage() total time: 0.095s
[Thu Oct 22 12:40:37 2009].123848 mapserv request processing time (loadmap
not incl.): 6.791s
[Thu Oct 22 12:40:37 2009].124004 msFreeMap(): freeing map at 0x6004c00.
And ms_error.txt for the render on the main map page:
[Thu Oct 22 12:40:20 2009].407990 msDrawRasterLayerLow(Dem): entering.
[Thu Oct 22 12:40:21 2009].391734 msDrawMap(): Layer 1 (Dem), 0.984s
[Thu Oct 22 12:40:21 2009].520934 msDrawMap(): Layer 12 (Washes), 0.129s
[Thu Oct 22 12:40:21 2009].536142 msDrawMap(): Layer 25 (roads1), 0.015s
[Thu Oct 22 12:40:21 2009].571742 msDrawMap(): Layer 26 (Roads), 0.035s
[Thu Oct 22 12:40:21 2009].572047 msDrawMap(): Layer 31 (mtrq), 0.000s
[Thu Oct 22 12:40:21 2009].572093 msDrawMap(): Layer 32 (elfeet), 0.000s
[Thu Oct 22 12:40:21 2009].572169 msDrawMap(): Layer 33 (copyright), 0.000s
[Thu Oct 22 12:40:21 2009].572337 msDrawMap(): Layer 34 (compass), 0.000s
[Thu Oct 22 12:40:21 2009].952978 msDrawMap(): Drawing Label Cache, 0.381s
[Thu Oct 22 12:40:22 2009].26008 msDrawRasterLayerLow(BLM Claim Names):
entering.
[Thu Oct 22 12:40:22 2009].30731 msResampleGDALToMap in effect: cellsize =
0.000035
[Thu Oct 22 12:40:22 2009].91613 msDrawGDAL(BLM Claim Names): using
RAW_WINDOW=0 0 952 712
[Thu Oct 22 12:40:22 2009].314730 msDrawMap(): Layer 24 (BLM Claim Names),
0.362s
[Thu Oct 22 12:40:22 2009].314869 msDrawMap() total time: 2.817s
[Thu Oct 22 12:40:23 2009].338078 msSaveImage() total time: 1.023s
[Thu Oct 22 12:40:23 2009].469088 msSaveImage() total time: 0.120s
[Thu Oct 22 12:40:24 2009].92737 mapserv request processing time (loadmap
not incl.): 4.596s
[Thu Oct 22 12:40:24 2009].92822 msFreeMap(): freeing map at 0x6004c00.
As you can see mapserver didn't even request a connection to the WMS layer
when print.html map was rendered.
Do you think I might be having problems with the spaces in the layer name?
Thanks for the information Stevebean
On Thu, Oct 22, 2009 at 11:51 AM, Steve Lime <Steve.Lime at dnr.state.mn.us>
wrote:
> What does a processed URL look like? That is, after MapServer has done the
> various substitutions.
> Typically when using MapServer tags in a URL context you should be using
> the escaped versions so
> that spaces and other characters are properly represented. For example:
> http:/localhost:8888/cgi-bin/mapserv?map=[map]&mapext=[mapext_esc]&layers=[layers_esc]&map_web=TEMPLATE+pgs/print.html&mapsize=1500+1182
> Does that make a difference?
> Steve
> >>> On 10/22/2009 at 1:42 PM, in message
> <731ed3bb0910221142g66ac67cavb1dff1eaa828b054 at mail.gmail.com>, Ruby
> <minerdiggins at gmail.com> wrote:
> > Thanks for your reply Steve,
> > I am unsure how I could share the app. I cannot host from my ISP and the
> > data approaches 5 GB.
> > I am using mapserver 5.2 on MacOsx 10.4.1 and ms4w 5.2 on WindowsXP
> ProSP3.
> > The app is plain vanilla- no python, mapscript, java, or third party
> > interfaces. Just straight html without frames, even the legend is html on
> > the map page. The few lines of javascript I use are not app related, just
> > invoking windows, sizing, calling a local app for gps download and the
> > button to this one url for print.html. All files are local to the server
> > except this one WMS layer.
> > I develop on the Mac and port to the Windows machine, The Windows machine
> is
> > not connected to the WAN. I test on both machines. I set up a dummy dns
> on
> > the LAN and ms4w on the Windows machine does try to connect when invoked
> > from the main window but makes not attempt for print.html, the same
> behavior
> > observed on the Mac version with a real WAN connection.
> > The WMS layer loads fine in several different map templates I've built.
> It
> > is only when the URL
> http:/localhost:8888/cgi-bin/mapserv?map=[map]&mapext=[mapext]&layers=[layers]&m
> > is called that mapserver does not attempt to connect the WMS layer. I
> > suspect something is missing in the above URL.
> > Thank you again,
> > bean
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091022/71d7bd50/attachment-0001.html
