[mapserver-users] PPH Mapscript - limit to number of shape objects
in a layer?
Alan Hale
alan.hale at btclick.com
Sat Oct 24 11:29:26 EDT 2009
Alan
Well, I think I just adapted code from Bill Kropla's "Beginning
Mapserver" (that was for point rather than polygon data). I should have
given it some more thought.
Your suggestion works fine and will run with a 32M limit.
Very many thanks for your help.
Alan
Alan Boudreault wrote:
> That's what I suspected too. I'm not sure if there is a reason why you
> keep ALL lineObj and shapeObj in arrays... but maybe you could try
> something like this:
> $i = 0;
> foreach($qresult as $row) {
> $ln = ms_newLineObj();
> $X = $row[1];
> $Y = $row[2];
> $ln->addXY($X-1000,$Y-1000);
> $ln->addXY($X+1000,$Y-1000);
> $ln->addXY($X+1000,$Y+1000);
> $ln->addXY($X-1000,$Y+1000);
> $shp = ms_newShapeObj(MS_SHAPE_POLYGON);
> $shp->add($ln);
> $shp->set(index, $row[0]);
> $layerPoi->addFeature( $shp );
> $i++;
> This will of course reduce the memory usage of your script ... if you
> don't need all those lineObj and shapeObj arrays. (You can always get
> the shapeObjs of the layer again later)
> Alan
> Alan Hale wrote:
>> I've just figured out that this is a PHP memory limit issue - raising
>> the limit in php.ini to 128M from the default 32M fixes the problem.
>> But can anyone suggest a more memory-efficient way of coding the
>> addition of square polygons to a dynamic layer?
>> Many thanks
>> Alan
>> Alan Hale wrote:
>>> Hi Alan
>>> Thanks for the reply. I'm displaying the map image via Overlib and
>>> so not getting any error messages- just no image. I know the limit
>>> is 11528 just by setting LIMIT on the database query and iterating
>>> to the max value. I've been trying to debug the script that
>>> generates the image but this is proving more difficult than I
>>> thought since various parameters are passed via Overlib so I will
>>> have to insert some dummy values.
>>> Hope to get back with more information later.
>>> Regards
>>> Alan
>>>> Hi Alan,
>>>> What's happen when you reach 11528? Is is a PHP error or a
>>>> mapserver error ? Could you show us the error?
>>>> Alan
>>>> On October 23, 2009 11:30:00 am Alan Hale wrote:
>>>>> Hi
>>>>> I'm using PHP Mapscript to construct a layer with 2km square polygons
>>>>> based on coordinates from a database query - thus:
>>>>> $i = 0;
>>>>> $ln[$i] = ms_newLineObj();
>>>>> $X = $row[1];
>>>>> $Y = $row[2];
>>>>> $ln[$i]->addXY($X-1000,$Y-1000);
>>>>> $ln[$i]->addXY($X+1000,$Y-1000);
>>>>> $ln[$i]->addXY($X+1000,$Y+1000);
>>>>> $ln[$i]->addXY($X-1000,$Y+1000);
>>>>> $shp[$i] = ms_newShapeObj(MS_SHAPE_POLYGON);
>>>>> $shp[$i]->add($ln[$i]);
>>>>> $shp[$i]->set(index, $row[0]);
>>>>> $layerPoi->addFeature( $shp[$i] );
>>>>> $i++;
>>>>> This seems to work fine UNTIL the query result reaches more than
>>>>> 11528
>>>>> rows (this number is exact). Is there a limit? Am I expecting too
>>>>> much
>>>>> here?
>>>>> Many thanks
>>>>> Alan Hale
>>>>> __________ Information from ESET Smart Security, version of virus
>>>>> signature
>>>>> database 4536 (20091023) __________
>>>>> The message was checked by ESET Smart Security.
>>>>> http://www.eset.com
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> signature database 4537 (20091023) __________
>>> http://www.eset.com
>>> http://www.eset.com
>> http://www.eset.com
__________ Information from ESET Smart Security, version of virus signature database 4538 (20091024) __________
http://www.eset.com
