[mapserver-users] AGG Rendering problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Oct 26 09:41:03 EDT 2009
Try adding MIMETYPE to outputformat. I guess that without it Mapserver is using default for jpeg requests. If you use, while testing, your own mimetype like
MIMETYPE "image/jpeg2" and in request use &FORMAT=image/jpeg2 you should be able to compare what happens with image/jpeg and image/jpeg2. If jpeg2 works you know that Mapserver if using your own imageformat because otherwise image/jpeg2 would not be recognised. Then rename AGG MIMETYPE to image/jpeg and see if the output now seems to be generated by AGG.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Tony Baylis
> Lähetetty: 26. lokakuuta 2009 15:15
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] AGG Rendering problem
> Hi all,
> This is my first post in a long time so be gentle...My
> problem is I have finally updated an old server to use
> MapServer 5.4.2 and want to use AGG rendering I have done
> this without a problem on another server earlier in the year
> but for some reason whenever I add the 'OUTPUTFORMAT'
> section and remove 'IMAGETYPE' I get a Connection Lost type
> error from the browser. Replace 'IMAGETYPE' and the
> connection is restored but the map is definitely not anti-aliased.
> Below is the relevant section from my mapfile and below that
> the output from a ./mapserv -v. Both outputs match the
> server that works.
> #IMAGETYPE JPEG
> OUTPUTFORMAT
> NAME "AGG_JPEG"
> DRIVER "AGG/JPEG"
> IMAGEMODE RGB
> END
> ./mapserv -vMapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
> SUPPORTS=FASTCGI SUPPORTS=GEOS INPUT=TIFF
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Here's hoping you can help.
> Tony
> Tony Baylis
> Spatial Information Specialist
> Resource and Exploration Mapping
> Suite 8, 290 Boundary St
> Spring Hill QLD 4000
> Ph 3832 1600
> Fax 3832 1603
> Mob 0419 759 131
> Email tony.baylis at resexmap.com.au
> www resexmap.com.au
