[mapserver-users] FW: Character symbology to follow line direction
Todd Harris
Todd.Harris at landgate.wa.gov.au
Tue Oct 27 19:48:55 EDT 2009
Thanks Bobb, but I believe this will only work for LINE layers (linear
features)?
I need the symbol to follow the boundary of a polygon, hence the reason
for creating the symbol.
Todd
-----Original Message-----
From: Bob Basques [mailto:bob.b at gritechnologies.com]
Sent: Wednesday, 28 October 2009 7:36 AM
To: Todd Harris
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] FW: Character symbology to follow line
direction
You can do this within a LABEL block, see here for more info:
http://mapserver.org/mapfile/label.html?highlight=follow%20auto
HINT: use "ANGLE auto" or "ANGLE follow"
bobb
Todd Harris wrote:
Hello list,
A little problem, I hope someone can help.
Using Mapserver 5.2 - I am attempting to use a character symbol: "|" as
a STYLE for the outline of a polygon class. However, I cannot get the
symbol to remain perpendicular to the polygon boundaries ie: the symbol
is always vertical. Can this be done or should I be using a vector or
point symbol somehow?
Symbol file:
SYMBOL
NAME "rawmat"
TYPE truetype
FONT arial
CHARACTER "|"
GAP 20 # distance between symbols
END
Mapfile
CLASS
NAME 'Extraction Areas'
STYLE
OUTLINECOLOR 0 0 0
WIDTH 1
ANTIALIAS TRUE
END #STYLE
STYLE
SYMBOL 'rawmat'
OUTLINECOLOR 0 0 0
SIZE 5
ANTIALIAS TRUE
END #STYLE
END #CLASS
Regards
Todd
This e-mail and any files transmitted with it are intended only for the
use of the addressee(s). It may contain information that is confidential
and privileged, in which case neither is intended to be waived or lost
by mistaken delivery to you. If you are not an intended recipient, any
use, interference with, disclosure, distribution or copying of this
material is unauthorised and prohibited. If you receive this e-mail in
error, please notify the sender by return e-mail and delete the message
and any attachments from your system. Unless specifically indicated,
this e-mail does not constitute formal advice or commitment by the
sender or the Western Australian Land Information Authority (Landgate).
Information in this message not relating to the official business of
Landgate shall be understood as neither given nor endorsed by it. It is
your responsibility to check any attachments for viruses and defects
before opening or sending them on. Landgate's liability is limited to
re-supplying affected attachments.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091028/4e4f4cff/attachment.html
