[mapserver-users] Help with NQuery error (CGI)
Paul james
pauljame at gmail.com
Thu Oct 29 08:57:22 EDT 2009
Hello guys...
I´m got this error when trying to execute a Nquery :
http://localhost/cgi-bin-54/mapserv.exe?map=Map.map&mode=nquery&LAYERS=TEST&mapext=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&imgext=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&map_size=1221+762&imgxy=1221+762&imgbox=0+0+1221+762
msDrawMap(): Image handling error. Failed to draw layer named 'TEST'.
But, If I execute the same url with "mode=map", the image is generated
fine... What this error means?
TEST Layer
LAYER
NAME TEST
GROUP "TE"
TYPE polygon
STATUS ON
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "server=X;Integrated Security=false;database=X;uid=X;pwd=X"
DATA "the_geom from viw USING UNIQUE oid USING SRID=0"
CLASS
TEMPLATE "template.html"
NAME "X"
STYLE
OUTLINECOLOR 150 150 150
WIDTH 1
END
END
END
Thanks
Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091029/99c2ba9d/attachment.html
